JurassicZ Posted May 10, 2016 Share Posted May 10, 2016 (edited) As shown in the photo, I have a very small wear hole in the seal that goes down the back of the window. The passenger window did not drop quickly enough when opening the door. This was noted when I bought the car and they adjusted the window drop which is now fine and agreed to replace the seal. The seal was on back order and I am now only in a position to let the dealer have the car to get the seal replaced. My concern is that it seems that the seal goes all the way along the back and bottom of the hood and up both sides of the window. Can anyone advise how big and complicated the work is to replace the seal? Even though the dealer is doing it under warranty, my concern is with anyone messing with the hood at all, given some of the horror stories of having the hood adjusted so it clears the windows. My hood works perfectly well and there is no wear on the actual hood material. Should I let them do the work or accept the slight wear on the seal? Thanks Rob Edited May 10, 2016 by 370ZRDevon Quote Link to comment Share on other sites More sharing options...
Eddie f Posted March 20, 2019 Share Posted March 20, 2019 Mate did you get any joy with the seal .? Mines is the same . Quote Link to comment Share on other sites More sharing options...
