N4eay Posted May 9, 2016 Share Posted May 9, 2016 (edited) Hi all, As we all know there are LOADS of posts discussing the clutch on the 350, and we all know that the OEM clutch is not the easiest to use, I can do a better quick start in the Mrs A class 9/10 times. Anyway, what I would like to know is, are there replacements clutches out there that if installed would provide the following characteristics:- Low biting point - (Like most cars) Firm and consistent bit point, to avoid any clutch burn when launching. Less pedal travel. FYI I'm looking for HR options. Thanks Edited May 9, 2016 by N4eay Quote Link to comment Share on other sites More sharing options...
KyleR Posted May 9, 2016 Share Posted May 9, 2016 Just adjust your clutch pedal. There's a guide in the FAQ section Quote Link to comment Share on other sites More sharing options...
Rook Posted May 9, 2016 Share Posted May 9, 2016 I may be wrong, but I believe the travel is inherent in the pedal itself, as there's a strut-like arm that takes up some strain first. The problem with adjusting it is you'll very likely lose cruise control, as it has a sensor. Quote Link to comment Share on other sites More sharing options...
Caracol Posted May 25, 2016 Share Posted May 25, 2016 Hi I have a 2006 301 hp 350z and need to replace the clutch. Can anyone tell me if there is a difference in clutches according to year and where I can get an economical replacement. Quote Link to comment Share on other sites More sharing options...
ZEUS Posted May 25, 2016 Share Posted May 25, 2016 Best to contact some traders on here like Clark Motorsport , cougar store, Tarmacsportz etc. They will be able to give you some advice based on your needs. Quote Link to comment Share on other sites More sharing options...
-G- Posted May 25, 2016 Share Posted May 25, 2016 Supercoppermix twin plate in the Nismo. Amazing. Like night and day to my stock Z Quote Link to comment Share on other sites More sharing options...
Richf Posted May 25, 2016 Share Posted May 25, 2016 You cant really have a low biting point and reduced travel but adjustments can be made, usually a lot of clutch issues on the HR can be traced to the fairly poor stock slave cylinder for which there is no cheap fix . The kits that replace the clutch slave cylinder like the Xtreme ones seem to give a more consistent feel as does fitting the single mass flywheel , coupled with a braided line at the same time is pretty much as good as it gets Quote Link to comment Share on other sites More sharing options...
