Jay Kay Posted May 8, 2016 Share Posted May 8, 2016 When I bought my DA machine I got the Sonus kit with 4 different grades of polish, each with its own pad. The kit works well but I just can't get on with stage 3 which is the SFX-3 final finish Polish. This just doesn't seem to work as well as the 2 stages prior or stage 4 which is a sealant. It doesn't work in nicely and takes more work that I think it should to remove. Any recommendations for a finishing polish that I can use in its place? Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted May 9, 2016 Share Posted May 9, 2016 Scholl S30+. Although I've never used the Sonus polishes, so out of interest when you say it doesn't work as well as the others, in what way? Just out of interest more than anything. Quote Link to comment Share on other sites More sharing options...
Ekona Posted May 9, 2016 Share Posted May 9, 2016 +1 on the S30+, I wouldn't be without it in my kit. Quote Link to comment Share on other sites More sharing options...
Jay Kay Posted May 9, 2016 Author Share Posted May 9, 2016 It just seems like harder work than it should be. Doesn't break down well at all, leaves loads of residue on the car and then when removing its a pig. Quote Link to comment Share on other sites More sharing options...
Jay Kay Posted May 9, 2016 Author Share Posted May 9, 2016 Everything thing else I apply machine needs only the minimum of effort to buff off, this stuff just doesn't want to shift. Often wonder if its gone off Quote Link to comment Share on other sites More sharing options...
Ricey Posted May 9, 2016 Share Posted May 9, 2016 Another vote for Scholl Sent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ricey Posted May 9, 2016 Share Posted May 9, 2016 Everything thing else I apply machine needs only the minimum of effort to buff off, this stuff just doesn't want to shift. Often wonder if its gone off Are you using a fresh pad? Are you using the right pad? Are you cleaning the pads thoroughly when you finish? Are you working the product too fast? Are you working the product too long? Are you working you big of an area? Sent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jay Kay Posted May 9, 2016 Author Share Posted May 9, 2016 Freshly washed pad every time using them with the pressure and speed etc as per the sonus guides. As I say, everything else I've used on the DA machine goes on a treat (splitting panels into small areas at a time) it's just this one particular polish. I'm sure it's possibly gone bad even though I've only had it for less than a year and began using it as soon as I got it - always with the same results. I'll order up some Scholl shortly as I need to get some brushes anyway. Sent from my HTC One using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ricey Posted May 9, 2016 Share Posted May 9, 2016 Odd one that mate. I can't say I've used Sonus but I don't think they're too bad from what I hear. Unlikely it's gone bad but you never know. In my experience it gets easier to wipe down as you progress through the stages so it's unusual that stage 3 is being a bugger. Sent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jay Kay Posted May 9, 2016 Author Share Posted May 9, 2016 Agreed. Oh well, I'll ditch it shortly once it's replacement arrives. Thanks all for the recommendation for Scholl Sent from my HTC One using Tapatalk Quote Link to comment Share on other sites More sharing options...
