Boot doesn't seem shut properly
bigfoot
Was out yesterday in my 2012 370z when i went over some bumps in the road and i heard a rattle from the back of the car.
When i got home i noticed that the boot looked shut but if i pushed down on it there was movement,
Only moves down about 2 or 3 cm's so tried shutting it a bit harder but still the same,
Having looked on here and read about the boot release spring, which also I've noticed it does take 2 pushes of the button to open, but this seems a different issue,
Is there any adjustment in the boot locking latch mechanism ?
Edited by bigfoot
Thanks glrnet,
I've had a look today and all the latch loop and latch mechanism seems still bolted down tight.
I've been reading the threads about the boot release spring issues,
Which also was a problem,
I've attached some small pieces of rubber pads i had to the end of the springs and the 2 rubber bungs by the latch loop and it seems to have cured both the loose tailgate and now it opens on just 1 push of the release button.
