Hairyaardvark Posted May 3, 2016 Share Posted May 3, 2016 Hey guys, Wanting to remove my front bumper so as to fit white/clear repeater lenses. I can see how the bumper comes off but now how to deal with the headlight washers. Can anyone advise how to remove the bumper without damaging them? Do they just pop off on the outside? Thanks David Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted May 3, 2016 Share Posted May 3, 2016 Its just 2 water pipes i believe! They kinda just pull off! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 3, 2016 Share Posted May 3, 2016 You will not require to disconnect the washer stuff to get to the lenses. Just slip the bumper forward and lay it on a blanket to avoid scratching and swop out the lenses Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted May 4, 2016 Share Posted May 4, 2016 I used four bits of wood baton on the ground and just rested the bumper on those. Quote Link to comment Share on other sites More sharing options...
Hairyaardvark Posted May 4, 2016 Author Share Posted May 4, 2016 Cool, thanks guys. I guess I'm just going to have to pull the bumper off and see. I thought there must be some way of disconnecting the headlight washer plastic caps on the outside of the bumper first. But it sounds like there isn't, and I should just pull the bumper? Unfortunately I am going to have to wrestle with the bumper a bit once it is off because the second part of the job I have to do is somehow release all the corroded screws connecting the undertray to the bumper. They are so corroded I just plan to cut around them in the soft plastic of the undertray (I have a new undertray waiting to fit). But I'll then still need to extricate them from the bumper holes, once it is off. I am predicting a pitched battle and mucho swearing Right now they just turn and turn, ripping the plastic where they grip the undertray Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted May 5, 2016 Share Posted May 5, 2016 Four of my undertray bolts were solid and I cut them off.The others after a night soaking in WD40 came off ok. Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted May 11, 2016 Share Posted May 11, 2016 As,Zeezeebaba mention, it might be a good idea the night before drowning the bolts with penetrating oil just to help them on their way. Quote Link to comment Share on other sites More sharing options...
