I just realised that I never fitted oil pick up spacer when i fitted my oil pan spacer, but always wondered what that aluminum block is for...and while looking at the pictures of the Stillen oil pan I realised what it's for :scare:
No doubt I'm either lost 2 bolts that came with it or mixed them up with all bolts.
Does anyone know what's the size of original bolts? So i can get some sourced before doing the job.
Thanks all in advance :)
Same size as the OEM bolt + extra length for the thickness of the spacer.
Make sure that you fit good quality spring washers and that you fit a bolt and not a set screw.
I managed to find bolts that came with the spacer.
Original bolts never had any washers fitted...so I fitted new ones without washers as well. You think it's bad and it will get loose?
You made me so paranoid that I even had a dream about them bloody bolts :lol:
You know your stuff, so I trust your word and will strip it all again later on today and fit spring washers.
Good job I didn't put any oil in yesterday and double good job that I bought 2 tubes of sealant :lol:
Yea I torqued it properly and used a bit of that grey sealant on both sides of the spacer.
Hmmm....do I strip it all again or do I not? Lol
F**k it...I strip it all down again and re-do with washers and may be a drop of thread lock.
Rather spend 1hr redoing it than it becoming lose and having oil starvation/blown engine lol
