Wiseco High Comp Pistons VQ35DE
simon da silva
Hey People!
a set of 6 used Wiseco pistons. They have done around 800km, and was pulled from my mates engine as he wanted to go FI!
Had them sitting on the shelf for way to long now, and its time to find some one to put them into good used.
new they are like £600
Im selling them for retarded £150 including shipping!
Specs!
Bore mm/Inch - 95.50/3.760
Over Sizes - Std.
Stroke - 3.205/81.4
Rod Lgth. - 5.669/144
Comp Ht. - 1.168/29.67
Head cc's - 57
Dome Dish - -10
Gasket Thkness - .024/0.6
Deck Clearance - .024-/0.6-
Block Ht. - 8.464/215
Comp. Ratio - 8.8
Pin Dia - .866/22 mm
Gram - 371
Foot Notes - 1
Ring - 9550XS
Comp ratio 8.8? That's a low comp piston?
Not being a that, could genuinely be interested, just need to crunch the numbers as I already have high comp heads
Hey Ben!
I trippled checked this today! The pistons clearly says 6606M955!
and spec for these pistons are Nissan 350Z Vq35 4V Domed +7cc 95.5. Bore: 95.5mm. Comp Height: 29.67. Comp Ratio: 11.0:1. Dome Volume: 7. Gram Weight: 375. Rod: 144.2. Stroke: 81.4.
So high compression piston! I think the box might be from the newer pistons when the engine was rebuild for the FI build!
  • 3 years later...
  • 1 month later...
