Jay M1988 Posted April 19, 2016 Share Posted April 19, 2016 Morning guy's, Done some searching on both google and the forum. Ive seen a few threads but they don't quite answer my questions. Firstly I can work on the 350 as Ive fitted hsd coilovers and changed brakes also. My questions are: 1 - Few threads say fit the drop links/replace with the car on the ground, is this a must? As the car is very hard to work under due to the height of it, can it be jacked up on the front (both sides) to replace both fronts then visa versa the rears. 2 - Also people advise to set the links to the oem length then adjust accordingly. Little vague on this one as if I set it to oem id surely have the same knocking problem and would mean Im constantly tinkering dropping the car testing then lifting it back up. Is their not any way of knowing when you've set it to the correct height to take up any slack. Just looking for some help and guidance from people whove fitted the droplinks listed above. Ive also watched the youtube vid and read the whiteline instructions supplied. Much appreciated. Quote Link to comment Share on other sites More sharing options...
Richf Posted April 19, 2016 Share Posted April 19, 2016 Not used the whiteline ones but have used other adjustable ones 1) No issues doing them on a ramp just do one side at a time and the roll bar should stay where its put 2) I adjusted mine to the stock length, you will have to expand on your knocking issue Quote Link to comment Share on other sites More sharing options...
Jay M1988 Posted April 19, 2016 Author Share Posted April 19, 2016 (edited) Hey Rich, the knocking began not long after I fitted the coilovers say a few months driving, only on the front it seems but Ive bought all 4 adjustable drop links as I prefer to keep ontop of any wear and tear and refresh the suspension with new parts. To ensure it was the drop links I removed them and tied em away and rolled the car down the road of which it usually knocks due to the ground being uneven, the noise had gone. Ive no access to ramps unfortunately just jacks. Edited April 19, 2016 by Jay M1988 Quote Link to comment Share on other sites More sharing options...
Richf Posted April 19, 2016 Share Posted April 19, 2016 (edited) Probbaly just worn out links then so stock length should be fine , I'm more a fan of stock replacements to be honest , first thing I did to my car was swap out the SPL links for stock ones Doing it on jacks will be fine but might take a little longer Edited April 19, 2016 by Richf@H-Dev Quote Link to comment Share on other sites More sharing options...
Jay M1988 Posted April 19, 2016 Author Share Posted April 19, 2016 Cheers Rich, I understand its a simple task swapping out its more the adjustments required Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted April 19, 2016 Share Posted April 19, 2016 (edited) You can jack the car up, put it on axle stands - fit them at the same length as the originals. Easy. Ideally to adjust them, put blocks of wood under the car, when it's on a flat surface, then you can adjust the lengths shorter/longer as required. See this post: http://www.350z-uk.c...riving-me-nuts/ Or just search on google, doesn't matter what car, the principle is the same. Edited April 19, 2016 by RobPhoboS Quote Link to comment Share on other sites More sharing options...
Hairyaardvark Posted May 3, 2016 Share Posted May 3, 2016 Fitted mine last weekend, same length as normal did the trick ... had to encourage the second side of the roll bar 'up' a fraction with a jack to fit the second droplink, once the first had been loosely fitted Quote Link to comment Share on other sites More sharing options...
Jay M1988 Posted May 4, 2016 Author Share Posted May 4, 2016 Yeh mate I have had the above problem after refitting the oem droplinks when installing coilovers just takes a lil persuasion. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 4, 2016 Share Posted May 4, 2016 http://www.powergrid...nstructions.pdf Quote Link to comment Share on other sites More sharing options...
