Loggy747 Posted April 18, 2016 Share Posted April 18, 2016 Hi all, i just had a Wasso plenum spacer arrive at the weekend so while I was fitting it I thought it would be a good time to change the plugs as well. If you are looking at the engine bay from the front of the car there is a fuel line which goes to something which is bolted down with two 10mm bolts to the left side of the plenum. I had to take this off to get at the top left coil pack. However when I was removing it, I must have damaged the o-ring seal 😔. Then when I put the car back together petrol started squirting out of it. I tried another seal I had in the garage and it worked for a while before starting to squirt again. Can anyone identify what it is so I could order the proper o-ring? Sorry I couldn't get a closer photo, I'm off to the airport and forgot to take one this morning! Cheers, Orran Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ebized Posted April 18, 2016 Share Posted April 18, 2016 Fuel damper. Quote Link to comment Share on other sites More sharing options...
ZEUS Posted April 18, 2016 Share Posted April 18, 2016 Fuel damper. +1 Quote Link to comment Share on other sites More sharing options...
Loggy747 Posted April 18, 2016 Author Share Posted April 18, 2016 Cheers guys! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Loggy747 Posted April 18, 2016 Author Share Posted April 18, 2016 Found it! Where would we be without the interweb 😠Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Loggy747 Posted April 18, 2016 Author Share Posted April 18, 2016 Actually I don't really fancy getting one sent from other side of the Atlantic! Does anyone know where I could source one in the uk? Should I just contact Nissan? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Vlad Posted April 18, 2016 Share Posted April 18, 2016 Try: ZMANALEX Clark Motorsport Cougar Store All traders on here, good prices and you know you will get right part and quick. Failing that, try Nissan. Quote Link to comment Share on other sites More sharing options...
Loggy747 Posted April 18, 2016 Author Share Posted April 18, 2016 I'll give them a try, cheers Vlad! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
