Steve3085 Posted April 17, 2016 Share Posted April 17, 2016 Hello all, New to forum, have popped a quick post in the welcome section. My 350 hasn't been serviced in about two years. The previous owner said he didn't do enough miles. To me that's not what you should do a service on. It should be done every year.... Anyway, he didn't have any service history with it, so I'm going to get everything done! So I'm here to ask for a list of things to get done. Oil/filter Air filter Brake pads Fuel filter (does the 350 have one?? Nissan couldn't tell me) Anything else I'm missing?? Thanks Steve. Quote Link to comment Share on other sites More sharing options...
jowen7448 Posted April 17, 2016 Share Posted April 17, 2016 If history is lacking I would also go for Gearbox oil (optionally with some molyslip) Diff oil Clutch and brake fluid Spark plugs Coolant Quote Link to comment Share on other sites More sharing options...
jowen7448 Posted April 17, 2016 Share Posted April 17, 2016 And belt/belts (1 on HR, 2 on DE) Quote Link to comment Share on other sites More sharing options...
jowen7448 Posted April 17, 2016 Share Posted April 17, 2016 Sorry for numerous posts, phone won't let me edit: Fuel filter is part of the pump itself I believe and not serviceable separately. Quote Link to comment Share on other sites More sharing options...
Ekona Posted April 17, 2016 Share Posted April 17, 2016 I'd do a P2, and then anything else it may need based on the age of the car (so possibly plugs etc). Quote Link to comment Share on other sites More sharing options...
kbad Posted April 17, 2016 Share Posted April 17, 2016 My recommendation (budget permitting) would be a P3 service and plugs , at least would give some peace of mind - Just my penny's worth Quote Link to comment Share on other sites More sharing options...
jowen7448 Posted April 17, 2016 Share Posted April 17, 2016 Is P3 not the same as P2? Quote Link to comment Share on other sites More sharing options...
kbad Posted April 17, 2016 Share Posted April 17, 2016 My understanding of these are P1 Service - Engine Oil and Oil filter P2 Service –Engine Oil, Oil filter, Air Filter, Brake Fluid Change P3 Service – Engine Oil, Oil filter, Air Filter, Gearbox Oil, Differential Oil, Brake Fluid Change Quote Link to comment Share on other sites More sharing options...
Guest marcw79 Posted April 17, 2016 Share Posted April 17, 2016 I was in similar situation with mine ... Last owner was a dick didn't even keep receipts from self servicing ... Had everything done including belts and all the fluids and air con and plugs ... Nice warm fuzzy feeling ... And a slightly emptier bank account ... Sent from my Nexus 6 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Steve3085 Posted April 18, 2016 Author Share Posted April 18, 2016 Ok cool, I shall browse the forum for the correct fluids and get hunting for best prices. I was in similar situation with mine ... Last owner was a dick didn't even keep receipts from self servicing ... Had everything done including belts and all the fluids and air con and plugs ... Nice warm fuzzy feeling ... And a slightly emptier bank account ... Sent from my Nexus 6 using Tapatalk í ½í¸‚ I think I will get the same fuzzy feeling knowing that it's all good. Can you remember how much it cost?? Quote Link to comment Share on other sites More sharing options...
Guest marcw79 Posted April 18, 2016 Share Posted April 18, 2016 I'll look it up when I get home from work ... I keep my receipts Sent from my Nexus 6 using Tapatalk Quote Link to comment Share on other sites More sharing options...
jowen7448 Posted April 18, 2016 Share Posted April 18, 2016 Not sure about DE but for HR for plugs, oils, moly, belt, filters it was about 150 for the bits. That wasn't inclusive of any labour as got them and did myself. I think a full P3 from sly @ kaizer is 300 ish. You can find service prices on his website. Quote Link to comment Share on other sites More sharing options...
Guest marcw79 Posted April 18, 2016 Share Posted April 18, 2016 I had P3 plus 4 wheel alignment plus inner tie rod and new reflector plus aircon regas and leak test ... 300 labour and 250 parts give or take ... Sent from my Nexus 6 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Steve3085 Posted April 30, 2016 Author Share Posted April 30, 2016 So had the service done yesterday, and while we were doing it all, found that the rear discs are pitted and grooved 😔 so new rear discs are needed. I have grooved fronts, where is the best place to get grooved rears from? Quote Link to comment Share on other sites More sharing options...
Richf Posted April 30, 2016 Share Posted April 30, 2016 Is P3 not the same as P2? Yes p2 same as p3, includes air filter and brake fluid change over the p1 which is just oil and filter and inspection (We do an alignment check also) Quote Link to comment Share on other sites More sharing options...
jowen7448 Posted April 30, 2016 Share Posted April 30, 2016 Is P3 not the same as P2? Yes p2 same as p3, includes air filter and brake fluid change over the p1 which is just oil and filter and inspection (We do an alignment check also) I thought that was the case. Thanks for clarifying for me Quote Link to comment Share on other sites More sharing options...
