MrChow Posted April 15, 2016 Share Posted April 15, 2016 OK so I go out to my car this afternoon to check it all over, and apart from having a totally flat battery (which was replaced 2 months ago) I noticed that the Air Con belt has snapped. Will running my car be ok without it for now, and is it wise to replace the other belts at the same time?? I seem to remember someone saying about bypassing an idler pulley, cam someone kindly explain this too? Thanks folks Quote Link to comment Share on other sites More sharing options...
Rook Posted April 15, 2016 Share Posted April 15, 2016 Mine hasn't had an air con belt for ages, Nissan told me it was fine. I don't know why you'd have to replace both belts at once, but you might as well, since they're cheap and once you have access to one you have access to both. Quote Link to comment Share on other sites More sharing options...
Stutopia Posted April 15, 2016 Share Posted April 15, 2016 Assuming they were all replaced at the same time previously, which is fairly normal procedure, I s it not reasonable to assume the other would be in a similar state of wear? I'd change them as job lot. Soon. Quote Link to comment Share on other sites More sharing options...
MrChow Posted April 15, 2016 Author Share Posted April 15, 2016 Assuming they were all replaced at the same time previously, which is fairly normal procedure, I s it not reasonable to assume the other would be in a similar state of wear? I'd change them as job lot. Soon. Think it's fairly safe to assume that. Any traders on here do the Gates micro v belts?? Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted April 15, 2016 Share Posted April 15, 2016 Most of them have gates belts in stock. If not eBay £25 delivered for gates. Quote Link to comment Share on other sites More sharing options...
