Fault Code P1283 - help needed
samu23
Hi All
I have a recurring EML fault code of P1283, which seems to come on after about 30 minutes of driving after being reset.
I have done a search and found a few threads on here and online of people having a similar issue but none of the threads have had solutions added.
A little bit of background:
- Recently fitted a pop charger
- The car struggled to pass its MOT on emissions - the mechanic said the fuel trims were running at 100% at times.
- The car seems to drive ok with no loss of power or limp mode
From this site it looks to be one of the A/F sensors, is it a case of replacing it and see if the issue comes back?
http://www.autocodes...283_nissan.html
I'm new to all this so any help would be much appreciated.
Thanks,
Sam
Edited by samu23
Thanks Alex.
It's going in for a service on Tuesday so hopefully they can sort it.
I have only been driving it gently since, would you say it's ok to drive until I get it sorted.
Looks like it's running lean which could be dangerous?
Do you have any sensors in stock? If so can you pm me a price?
  • 2 years later...
