Bigger Throttle body
350z tt
Im so far behind on the kit, been busy on houses and getting my z track ready for this year.
But, NWP do a kit if you want to order from the states, if you don't I am mid way through getting an adapter plate made toount same tb amd harness as nwp kit for less money. Group buy will go up on here at the time :)
Removing restrictions from an FI setup is just as important as n/a.
Boost is a measure of restriction, free up the exhaust and inlet and ypu can run the same power at a lower boost levels and therefore improve reliability and reduce the heat generated.
Just because you 'can' squeeze 600bhp from the stock setup by cranking up the boost doesn't mean it's the right way to do it.
