RICHIERICH Posted January 17, 2008 Share Posted January 17, 2008 HI EVERYONE, Does anybody know where you can get clear indicator bulbs FRONT AND BACK (back are different also)-(obviously flash amber) for 07 onwards 350z, there not the bayonet type like philips do! silver vision for example. I think they do them in LED, they are wedge type, big version of the 501/T10 bulb. Or if any body has fitted LED type, did you have problems with flash rate? ordid you fit load resistor? Many thanks Regards RICHIERICH. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted January 17, 2008 Share Posted January 17, 2008 Hi and to the forum I got my silver indicator bulbs from here. I don't know whether it's the same fitting for MY07 http://www.jdmperformance.co.uk/item_de ... =449002189 Quote Link to comment Share on other sites More sharing options...
RICHIERICH Posted January 17, 2008 Author Share Posted January 17, 2008 HI, Thanks, No there WY06 OR 07. I bought the normal silver ones after being given wrong advice from Nissan Maintenance. Quote Link to comment Share on other sites More sharing options...
RICHIERICH Posted January 17, 2008 Author Share Posted January 17, 2008 I believe they are 7440 fitting/size type? If I can avoid messing around too much I will. If the flasher unit is easy to change I will by LED type. Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 19, 2008 Share Posted January 19, 2008 not sure but can you fit an inline resistor - as they do with bike led indicators to stop them flashing too fast ? just a thought Quote Link to comment Share on other sites More sharing options...
N15MNO-Daron Posted January 19, 2008 Share Posted January 19, 2008 Im confused.. are the indicator bulbs different for 07? i thought 03-06 take the bayonet type? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted January 19, 2008 Share Posted January 19, 2008 Im confused.. are the indicator bulbs different for 07? i thought 03-06 take the bayonet type? Nope the 03-05 take the large wedge type. I just ordered mine from JDM-Performance Quote Link to comment Share on other sites More sharing options...
Zummertor Posted January 19, 2008 Share Posted January 19, 2008 Have a look at Philips Silver Vision WY21W, i recall someone else on here got them. These might be right fit http://www.jdmperformance.co.uk/item_detail.php?prodID=449002189 Quote Link to comment Share on other sites More sharing options...
Chris`I Posted January 19, 2008 Share Posted January 19, 2008 Have a look at Philips Silver Vision WY21W, i recall someone else on here got them. These might be right fit http://www.jdmperformance.co.uk/item_detail.php?prodID=449002189 Thats what I have on the way Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 19, 2008 Share Posted January 19, 2008 Have a look at Philips Silver Vision WY21W, i recall someone else on here got them. These might be right fit http://www.jdmperformance.co.uk/item_detail.php?prodID=449002189 Thats what I have on the way i've got those front and rear Quote Link to comment Share on other sites More sharing options...
N15MNO-Daron Posted January 19, 2008 Share Posted January 19, 2008 Im confused.. are the indicator bulbs different for 07? i thought 03-06 take the bayonet type? Nope the 03-05 take the large wedge type. I just ordered mine from JDM-Performance How did u fit them? did u go from underneath the car or thru the wheel arches? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted January 19, 2008 Share Posted January 19, 2008 Im confused.. are the indicator bulbs different for 07? i thought 03-06 take the bayonet type? Nope the 03-05 take the large wedge type. I just ordered mine from JDM-Performance How did u fit them? did u go from underneath the car or thru the wheel arches? Not got them yet, waiting for delivery. Sure Gixx can shed some light. I think for the front you can get at it from above. Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 19, 2008 Share Posted January 19, 2008 the front ones you just, lift the bonnet undo the top bolt on the headlight and you can ease it up very slightly and you can get your hand down the back and turn the holder the rear - take the brake lights out (only 3 bolts) and you can reach down to the rear indicators Quote Link to comment Share on other sites More sharing options...
RICHIERICH Posted January 19, 2008 Author Share Posted January 19, 2008 Hi guys the bulbs are not bayonet they are capless/wedge type fit like the sidelights, they are T20 bulbs as I have found out. A company called silvertek do them. They are similar at rear indicators aswell but not bayonet(wy21w). Regards Richard Quote Link to comment Share on other sites More sharing options...
N15MNO-Daron Posted January 19, 2008 Share Posted January 19, 2008 the front ones you just, lift the bonnet undo the top bolt on the headlight and you can ease it up very slightly and you can get your hand down the back and turn the holder the rear - take the brake lights out (only 3 bolts) and you can reach down to the rear indicators Cheers ..thats much better.. was trying to go thru from wheel arches and cudnt find how to undo the trim there! Also there are 2 types..offset pins or straight pins? Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 19, 2008 Share Posted January 19, 2008 these are the ones for 03-06 not sure after that though http://www.jdmperformance.co.uk/item_de ... =449002189 Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 19, 2008 Share Posted January 19, 2008 not these as they keep selling to people :rant: http://cgi.ebay.co.uk/CHROME-INDICATOR- ... dZViewItem Quote Link to comment Share on other sites More sharing options...
N15MNO-Daron Posted January 19, 2008 Share Posted January 19, 2008 not these as they keep selling to people :rant: http://cgi.ebay.co.uk/CHROME-INDICATOR- ... dZViewItem Ok now i got it.. so all the 03-06 Z indicators are def not the bayonet fitting type.. only the large wedge (capless) style bulb. If u check the JDM wesite they also sell the ones shown on ebay and also list them for 350z too Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 19, 2008 Share Posted January 19, 2008 not these as they keep selling to people :rant: http://cgi.ebay.co.uk/CHROME-INDICATOR- ... dZViewItem Ok now i got it.. so all the 03-06 Z indicators are def not the bayonet fitting type.. only the large wedge (capless) style bulb. If u check the JDM wesite they also sell the ones shown on ebay and also list them for 350z too yeah spot on mate, the large wedge type front and rear, the side ones are just a smaller version Quote Link to comment Share on other sites More sharing options...
RICHIERICH Posted January 20, 2008 Author Share Posted January 20, 2008 There the ones mate. I purchased mine for £9.99 inc p&p at carisma style silvatec t20 bulbs. Nissan told me the rear ones were different spec again but not the bayonet ones. Are they T20's in rear also then yeah? Quote Link to comment Share on other sites More sharing options...
