dannyone90 Posted April 2, 2016 Share Posted April 2, 2016 Hi all, This may have been covered before but recently changed my rear wheels Std wheels to 18in 10j et12 with 265/35/18 After putting these on yesterday the slip light keeps flashing and there is no power But if I turn the traction control off it drives perfect Has anyone come across this issue before Kind regards Danny Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted April 2, 2016 Share Posted April 2, 2016 Did you change the fronts as well or just the rears? Quote Link to comment Share on other sites More sharing options...
dannyone90 Posted April 2, 2016 Author Share Posted April 2, 2016 Hi mate thanks for the fast responce just the rears atm Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted April 2, 2016 Share Posted April 2, 2016 That's your problem then I suspect - I make that a diameter difference of about 5% compared to the standard ~2.5%. That new difference is triggering the traction control because your car assumes the speed difference front-to-rear is you getting it all sorts of wrong and thus cutting the power. Fit the appropriate size wheels/tyres at both ends of the car and it should be fixed. 2 Quote Link to comment Share on other sites More sharing options...
jumping350 Posted April 2, 2016 Share Posted April 2, 2016 as Ilogikal has stated change your fronts to correct size as your rolling radius is out now Quote Link to comment Share on other sites More sharing options...
dannyone90 Posted April 2, 2016 Author Share Posted April 2, 2016 Ahh got you thank you for your help. What size would you suggest on the fronts :/ sorry when it comes to wheels n tyers I'm shocking haha Quote Link to comment Share on other sites More sharing options...
GMballistic Posted April 2, 2016 Share Posted April 2, 2016 Ahh got you thank you for your help. What size would you suggest on the fronts :/ sorry when it comes to wheels n tyers I'm shocking haha This is more of a guess on my part than fact (won't be far off though if not spot on) but if you're running a 10J ET12 with 265/35/18 on the rear then the front should be something like a 9.5J ET12 with 245/35/18's on. The ET & whether the alloy will fit over the brake caliper does depend on alloy wheel design though so best to check before buying (although it maybe fine). There is a car tyre calculator somewhere that maybe a member will post for you. 1 Quote Link to comment Share on other sites More sharing options...
billdingo Posted April 2, 2016 Share Posted April 2, 2016 There is a car tyre calculator somewhere that maybe a member will post for you. http://www.willtheyfit.com/ 1 Quote Link to comment Share on other sites More sharing options...
buster Posted April 2, 2016 Share Posted April 2, 2016 (edited) o/e front 225/45/18 8.j = 245/40/18 front 9 - 9.5j EXISTING NEW Diameter 659.7mm 653.2mm Circumference 2072.5mm 2052.1mm Poke 69.6mm 100.7mm Inset 133.6mm 140.7mm Speedo error 0% 1% Reading at 30mph 30mph 30.3mph Reading at 60mph 60mph 60.6mph Ride height gain 0mm -3.25mm Arch gap loss 0mm -3.25mm o/e rear 245/45/18 8.5j = 275/40/18 rear 10 -10.5j Diameter 677.7mm 677.2mm Circumference 2129.1mm 2127.5mm Poke 51.6mm 113.4mm Inset 115.6mm 153.4mm Speedo error 0% 0.07% Reading at 30mph 30mph 30.02mph Reading at 60mph 60mph 60.04mph Ride height gain 0mm -0.25mm Arch gap loss 0mm -0.25mm this is the closest rolling diameter i ve found and used without issue. Edited April 2, 2016 by buster 1 Quote Link to comment Share on other sites More sharing options...
fake ben taylor Posted April 2, 2016 Share Posted April 2, 2016 245 doesnt need a 9-9.5j wheel btw. An 8j would do and the tyre fit, im running 255 on 8.5j Quote Link to comment Share on other sites More sharing options...
dannyone90 Posted April 4, 2016 Author Share Posted April 4, 2016 Thank you to everyone for your help I messed up and bought the wrong size tyres 265 35 18 Danny Quote Link to comment Share on other sites More sharing options...
GMballistic Posted April 4, 2016 Share Posted April 4, 2016 Danny if you stick around and do a few more quality posts you'll soon hit the 15 posts required to post a for sale advert in the trading area. Please follow the rules listed in bold red text in the relevant area & you'll not have any problems. Link: http://www.350z-uk.com/forum/32-for-sale/ Otherwise try advertising your tyres properly on eBay or somewhere & I'm sure they'll sell. Good luck. Quote Link to comment Share on other sites More sharing options...
cs2000 Posted April 4, 2016 Share Posted April 4, 2016 fake ben taylor is correct, For a 9.5j wheel, you'd want something like a 265, for a 10.0j a 285 would fit well. Depending on the wheel, you should be able to get these sizes on the Z, 9.5 front 10 rear. Quote Link to comment Share on other sites More sharing options...
dannyone90 Posted April 5, 2016 Author Share Posted April 5, 2016 My bad sorry guys I'm still very new to the forum Massive help this place is 😊 Quote Link to comment Share on other sites More sharing options...
