AdrianL Posted March 31, 2016 Share Posted March 31, 2016 Hi all, Got all the above lights on the dash. After a bit of reading it sounded like the brake fluid - it was very close to max but I topped it up a tad and it disappeared for a few days. However it has came back on today - not sure what else to check? I've looked for error codes and nothing shows up Cheers, Adrian Quote Link to comment Share on other sites More sharing options...
Gudzy Posted March 31, 2016 Share Posted March 31, 2016 Check the brake lights are coming on, I had those dash lights come on when the brake pedal switch wasn't working. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 31, 2016 Share Posted March 31, 2016 Similar issue: http://www.350z-uk.com/topic/107132-dtc-code-c1142-and-c1109-help-please/ 1 Quote Link to comment Share on other sites More sharing options...
iwanprice12 Posted March 31, 2016 Share Posted March 31, 2016 Similar issue: http://www.350z-uk.com/topic/107132-dtc-code-c1142-and-c1109-help-please/ Yup similar issue with mine. Used a OBD 2 code reader, was the rear ABS sensor. Changed this & problem seems to have gone...so far,,, Quote Link to comment Share on other sites More sharing options...
AdrianL Posted April 2, 2016 Author Share Posted April 2, 2016 As mentioned no codes showed up when using a reader. I'll check the brake light today though - thanks guys Quote Link to comment Share on other sites More sharing options...
AdrianL Posted April 2, 2016 Author Share Posted April 2, 2016 So I just popped out. I turned the car on and pumped the brake pedal (brake lights working fine). Went to the supermarket and the lights were all on the dash. Parked up at the supermarket, got my stuff and on the way back the lights didn't return on. I've checked error codes using the pedal dance as well as using an OBDII reader and it's all clear... brake fluid is fine. If it was the ABS sensor there would be an error code, right? The only thing that has changed recently is I put the coilovers on, and had the geometry set up. However the lights didn't show up until a few days after that (must have done at least 100 miles).. Thoughts? Quote Link to comment Share on other sites More sharing options...
AdrianL Posted April 3, 2016 Author Share Posted April 3, 2016 Could tension on the ABS wire cause this issue? The placement of the bracket on the coilovers is higher than that of the OEM ones. I looked at it on full lock and there was some tention (not enough to stretch though). I've moved the bracket as low as it will go now and it has given it a bit more flex... see how it goes.. Quote Link to comment Share on other sites More sharing options...
