GT Driver Posted March 29, 2016 Share Posted March 29, 2016 Hi all, Looking for some advice here - I need to remove the front passenger side brembo caliper from the car. I was hoping to unscrew the bolt at the end of the brake line that goes directly into the caliper itself. Is there any way to minimise fluid loss so the reservoir doesn't empty? I don't have anything the plug the end of the brake line with nor do I really want to clamp the rubber brake line hose further up. I also want to reduce air getting in to the open end of the brake line. Any tips from someone who has done this before? Thanks. Quote Link to comment Share on other sites More sharing options...
Floydbax Posted March 29, 2016 Share Posted March 29, 2016 Pair of mole grips onto the hose might work, that's really the only way. You always have to bleed after removing the line. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 29, 2016 Share Posted March 29, 2016 You can only plug the hose or clamp it. Clamping is the easiest and cleanest. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 29, 2016 Share Posted March 29, 2016 Here you go. https://www.google.co.uk/?gws_rd=ssl#q=brake+hose+clamp Quote Link to comment Share on other sites More sharing options...
GT Driver Posted March 29, 2016 Author Share Posted March 29, 2016 Agreed, will have to bleed the line after reattaching the caliper. It's likely the car will be sitting up for a few days you see, so I don't want the brake system emptying. Are brake line clamps safe to use? Reading online it seems that some people are against it for fear of weaking/damaging the rubber hose. In my case it could be a few days of being clamped. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 29, 2016 Share Posted March 29, 2016 Of course they are safe to use, just nip them up to stop the flow of fluid. No need to squeeze the life out the hose. Quote Link to comment Share on other sites More sharing options...
