Dicky Posted March 29, 2016 Share Posted March 29, 2016 Had the brakes bled just before Xmas. After initial problems the main dealer finally managed to get the brake pedal rock hard (after giving them the bleeding order provided by the forum). I'm now noticing a greater travel on the pedal before resistance is felt. A friend suggests it could be a deteriorating flexi brake pipe expanding under pressure....anyone experienced this..? I was wondering if it might be a problem with the master cylinder. Can anyone help with suggestions please Quote Link to comment Share on other sites More sharing options...
Rook Posted March 29, 2016 Share Posted March 29, 2016 All 3 Z's I've driven have had a pretty long travel in the brake pedal, I assumed it was normal - watching... Quote Link to comment Share on other sites More sharing options...
Dicky Posted March 29, 2016 Author Share Posted March 29, 2016 Mine did as well before I had them bled. However afterwards the pedal travel appeared much less, but now it seems to have gone back to where it was. I understand that pad wear should make little difference, and I don't appear to be dropping fluid anywhere, so all I can think is there must be problem elsewhere. I could be wrong but I fancy I'd read some time ago of members having this kind of problem Quote Link to comment Share on other sites More sharing options...
