FallenAngelX Posted March 26, 2016 Share Posted March 26, 2016 Hey all, car has recently been serviced 500 miles ago ish. Oil will have been done. On idle if I'm say stopped at lights the low oil pressure light will flash up then goes when I start driving. On watching the gauge at idle pressure is barely above 0, it raises relative to rpm, max I usually see is 60 ish. How accurate is the oil pressure gauge? Should I have this looked at? Cheers 2 Quote Link to comment Share on other sites More sharing options...
Ricey Posted March 26, 2016 Share Posted March 26, 2016 Yup. Could be a faulty pressure switch. Could be a buggered engine. Could be wrong oil. You need it checking before you do any damage Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
davey_83 Posted March 26, 2016 Share Posted March 26, 2016 Ive heard of this before when using non gen oil filters. What level is the oil at? *cold engine Quote Link to comment Share on other sites More sharing options...
ZEUS Posted March 26, 2016 Share Posted March 26, 2016 Check the oil level first. Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted March 26, 2016 Share Posted March 26, 2016 Your first presumption is that the oil would have been changed, there are tons of horror stories about of yes yes yes they changed the oil but hey aft checking it they had not changed it even though you have paid them for it, so Do Not trust them on that one, Check your oil (bet it's low) if it is low top it up then check your pressure Quote Link to comment Share on other sites More sharing options...
FallenAngelX Posted March 26, 2016 Author Share Posted March 26, 2016 Your first presumption is that the oil would have been changed, there are tons of horror stories about of yes yes yes they changed the oil but hey aft checking it they had not changed it even though you have paid them for it, so Do Not trust them on that one, Check your oil (bet it's low) if it is low top it up then check your pressure Just checked, level is fine, just below max. The oil utilised is 5w30 Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted March 26, 2016 Share Posted March 26, 2016 Surprised but very good for you gauge next then or pressure switch Quote Link to comment Share on other sites More sharing options...
andybp Posted March 26, 2016 Share Posted March 26, 2016 best option is to fit a mechanical oil pressure gauge into the port the sender is plugged into (if you have one that is) this will tell you if you actually have low oil pressure if the oil pressure is good then its more likely to be the sender than the gauge 1 Quote Link to comment Share on other sites More sharing options...
glrnet Posted March 26, 2016 Share Posted March 26, 2016 I wouldn't be driving that anywhere until the oil pressure is checked properly 1 Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted March 26, 2016 Share Posted March 26, 2016 Does it use any oil? Quote Link to comment Share on other sites More sharing options...
Ricey Posted March 26, 2016 Share Posted March 26, 2016 I wouldn't be driving that anywhere until the oil pressure is checked properly Just take it to the garage!! By the time your buggered about buying/borrowing gauges etc you could have it sorted. If it is a true oil pressure issue you'll only end up another statistic in the Zed graveyard by delaying. Obviously if you're handy and have the tools then do it but otherwise just get it looked at asap Sent from my SM-G900F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted March 28, 2016 Share Posted March 28, 2016 Uh oh. This is exactly how mine was! Pressure drops to just over 0 when you stop the oil light pops on but goes if you blip the throttle right? Same as what mine started doing. Then it used more oil than fuel lol. Quote Link to comment Share on other sites More sharing options...
ZEUS Posted March 28, 2016 Share Posted March 28, 2016 Uh oh. This is exactly how mine was! Pressure drops to just over 0 when you stop the oil light pops on but goes if you blip the throttle right? Same as what mine started doing. Then it used more oil than fuel lol. Doom merchant 2 Quote Link to comment Share on other sites More sharing options...
FallenAngelX Posted April 13, 2016 Author Share Posted April 13, 2016 An update to this. The engine has been Terra cleaned New oil sensor has been put in Oil filter has been cleaned and so has the oil pan Issue still persists. Gauge is showing increasing oil pressure relative to rpm but it's sat low. 2k revs pulls around 25psi A oil pump and timing chain has been suggested but isn't guaranteed to fix the issue, but the labour will cost a good amount. Not sure where to go from here Quote Link to comment Share on other sites More sharing options...
davey_83 Posted April 13, 2016 Share Posted April 13, 2016 Genuine sender? As above - have a mechanical oil pressure gauge plumbed into the port the sender is plugged into a a gauge the can lie 1 Quote Link to comment Share on other sites More sharing options...
Richf Posted April 13, 2016 Share Posted April 13, 2016 (edited) What year is the car ? Very unlikely to be the oil pump Edited April 13, 2016 by Richf@H-Dev 1 Quote Link to comment Share on other sites More sharing options...
-Bradders- Posted April 13, 2016 Share Posted April 13, 2016 My issue was valve seal gone. Quote Link to comment Share on other sites More sharing options...
FallenAngelX Posted April 13, 2016 Author Share Posted April 13, 2016 Will check if it's a genuine sender tomorrow Year is 2003. Having my other mechanic collect it tomorrow. Quote Link to comment Share on other sites More sharing options...
