Facelift upgrades wants lights dash ect
matt3579
Its not that expensive to change the center console really ,best way is to try and buy the whole lot of parts from the same source at the same time which is what i did tbh. i bought it all from GDUK JAP PARTS LTD they are jap breakers so might be worth a try.
i just added it all up and was £297 inc postage
remember you need
whole center console lower section
gear surround
and the later heater switches/ dials
2x side panels
top cubby section down to heater controls
later heater control ECU
and if you still have OEM head unit and want to keep it you will need the later facelift unit to remove the front panel and swap with yours
not needed tho if you have after market head unit
and a bit of wiring work to relocate the hazard light switch
Edited by techinstaller
most parts on ebay now listings
151999501990
272183921205
281977548254
281976195194
281976201150
most parts with same seller i would try and bid / offer him a deal on the lot
be quick
I have no connection with the seller just though i would do a quick search out of curiosity for you
