Oil Velocity
Wicksaay
Hi Guys,
i believe the velocity of oil to use on a standard DE engine is 5W/30? do people use fully synth or part synth?
just need to get some for a top up! as I've just had a rebuild :)
Thanks in advance,
Jack
Hello Jack,
Check with the person who did the engine rebuild for you what oil they used?
You should be using Running In Oil or mineral based oil for the first 500-1000 mile after a rebuild to ensure bedding in of piston rings etc. Then flush and use 5w-30 fully synthetic as recommended.
Hello Jack,
Thanks mate,
I've now done 1100 miles with the new big bearings in it (was just a bottom end rebuild - completed by the garage i brought it from). I'm doing a long trip to Portsmouth from Cambridge at the weekend, its used a little oil since the rebuild (probably expected). I'm just looking to top it up with some normal oil and i'll dump the old stuff when i get back and refill completely with 5W/30! :)
