russyb Posted March 20, 2016 Share Posted March 20, 2016 found this on the bay guys bargain price 1 litre bottle @£8.50 well worth doing this at that price as its roughly half the price of everywhere else GENUINE NISSAN DIFFERENTIAL FLUID KE907-99932 1L BOTTLES http://www.ebay.co.uk/itm/222031326248?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 20, 2016 Share Posted March 20, 2016 Good spot. Quote Link to comment Share on other sites More sharing options...
Cro Posted March 20, 2016 Share Posted March 20, 2016 (edited) 1.4 litres on our cars isn't it? Edited March 20, 2016 by Cro Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 20, 2016 Share Posted March 20, 2016 1.4 litres on our cars isn't it? Yes, AFAIK it is (for the diff). 1 Quote Link to comment Share on other sites More sharing options...
Cro Posted March 20, 2016 Share Posted March 20, 2016 Doesn't post to Northern Ireland.... dammit Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 20, 2016 Share Posted March 20, 2016 Doesn't post to Northern Ireland.... dammit Well that's annoying for you. Bummer. Quote Link to comment Share on other sites More sharing options...
Smc1992 Posted March 21, 2016 Share Posted March 21, 2016 Ive bought some, thanks for sharing this! 👠Quote Link to comment Share on other sites More sharing options...
russyb Posted March 21, 2016 Author Share Posted March 21, 2016 No probs thought I'd share the wealth Quote Link to comment Share on other sites More sharing options...
Jonny B Posted March 23, 2016 Share Posted March 23, 2016 Thanks for the heads up, I got 2L of it bought Quote Link to comment Share on other sites More sharing options...
SUPRAWOOKIE Posted March 24, 2016 Share Posted March 24, 2016 Got myself some bottles on the way too, thanks for sharing! Quote Link to comment Share on other sites More sharing options...
Barkerm87 Posted March 25, 2016 Share Posted March 25, 2016 Bought the only bottle they had left. How much is needed for oil change? Quote Link to comment Share on other sites More sharing options...
russyb Posted April 30, 2016 Author Share Posted April 30, 2016 Back in stock again guys only 5 bottles available http://pages.ebay.com/link/?nav=item.view&id=222087819939&alt=web Quote Link to comment Share on other sites More sharing options...
Barkerm87 Posted August 18, 2016 Share Posted August 18, 2016 Ive come to finally get the oil changed, read the back of these bottles, they are NOT to be used when a LSD fluid is required. Making these two bottles redundant to me....great. Quote Link to comment Share on other sites More sharing options...
KyleR Posted August 18, 2016 Share Posted August 18, 2016 Ive come to finally get the oil changed, read the back of these bottles, they are NOT to be used when a LSD fluid is required. Making these two bottles redundant to me....great. This is what Nissan use in our diffs. I'm not aware of any other kind of magic LSD fluid other than oil Quote Link to comment Share on other sites More sharing options...
350_Jer Posted August 21, 2016 Share Posted August 21, 2016 I've just bought 2 bottles of this too and noticed what it says about not for LSD's as well. This is definitely ok to use in a standard LSD then? Was just going to email the seller and thought I'd check on here first, glad I did now! Quote Link to comment Share on other sites More sharing options...
Jonny B Posted August 21, 2016 Share Posted August 21, 2016 I bought this oil to do an oil change in my track car diff. I noticed the same about not using in LSD. However when I enquired about it this is how it was explained to me. Because the LSD is a viscous type it has an oil/ fluid inside the actual diff centre for it to work, this part remains sealed and the fluid is not changed (you wouldn't be able to change it without stripping the diff down anyway) So what it's saying on the bottle is this oil is NOT for the viscous LSD diff centre. When you do an oil change like you are suggesting, you drain the diff case out and refill it, this IS the correct oil for that. So basically this oil is lubricating the crown wheel and pinion, bearings etc. The two lots of oil/ fluid never mix between the diff centre and what's in the diff casing, you only ever change what's in the casing and this is the correct oil for it. This is how I had it explained to me and how I understood what I was being told. If I've not got it 100% correct I apologise and will stand corrected. Although I thought it was worth a mention and hopefully it will help others on here who were confused as I was wether or not to use this oil. Quote Link to comment Share on other sites More sharing options...
350_Jer Posted August 21, 2016 Share Posted August 21, 2016 Ah, that makes sense! Thanks Quote Link to comment Share on other sites More sharing options...
varley16 Posted August 27, 2016 Share Posted August 27, 2016 Purchased, thanks for sharing. Quote Link to comment Share on other sites More sharing options...
