Clutch slave cylinder and hose
Y5ave
Hi does anyone know why the clutch slave cylinders fail on 350zs ? I've heard
The hose can get very hot and this damages the piston seals because the fluid
Gets heated .
Your assumption is correct.
The rubber hose and oem fluid can not handle the heat from the exhaust/cat on the DE.
Braided line, high temperature fluid and a new oem slave usually fixes the issue.
