Y5ave Posted March 19, 2016 Share Posted March 19, 2016 Hi does anyone know why the clutch slave cylinders fail on 350zs ? I've heard The hose can get very hot and this damages the piston seals because the fluid Gets heated . Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 19, 2016 Share Posted March 19, 2016 I'm assuming you meant to post this in the 350Z area so I've moved it here. Hopefully someone more knowledgeable on the subject will be along shortly. Welcome aboard btw. Quote Link to comment Share on other sites More sharing options...
Y5ave Posted March 19, 2016 Author Share Posted March 19, 2016 Thanks I'm a newbie as you can see already ! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 19, 2016 Share Posted March 19, 2016 Hi does anyone know why the clutch slave cylinders fail on 350zs ? I've heard The hose can get very hot and this damages the piston seals because the fluid Gets heated . Your assumption is correct. The rubber hose and oem fluid can not handle the heat from the exhaust/cat on the DE. Braided line, high temperature fluid and a new oem slave usually fixes the issue. 1 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 19, 2016 Share Posted March 19, 2016 ^^ ...And there is the more knowledgeable man on the subject. Quote Link to comment Share on other sites More sharing options...
