Rear washer not working
gort
I believe it's a shared fuse for the front & rear washer jet motors so if the front one still works then the fuse is ok.
Can you hear the motor going when you pull on the stalk for the rear wash? If you can't hear the motor then that'll be your problem.
Replacement motor here: http://www.amazon.co.uk/Blue-Print-ADN10316-Washer-Pump/dp/B00B90LE00
If you can hear the motor going then you're going to have to investigate further... Is there washer fluid in the tank?, Are all the pipes connected? (check your headlining inside the car near the rear in case a pipes popped off) etc.
Let us know how you get on. :thumbs:
Replacement motor here: http://www.amazon.co...p/dp/B00B90LE00
I believe that this may be a front pump.
Should be the rear pump Alex.
I got the part number from Veeg33 from when he replaced his rear windscreen washer motor. ;)
Post n#125: http://www.350z-uk.com/topic/91440-veeg33s-slow-dose-of-zeditus/page__st__120
BluePrint Nissan 350Z rear washer pump motor: Part n# ADN10316
BluePrint Nissan 350Z front washer pump motor: Part n# ADN10315
  On 18/03/2016 at 18:53, gort said:
can't hear any motor, so I guess it's knackered,
rear motor http://www.ebay.co.u...w-/231742964107
Yep that looks like the right part number gort.
Fairly easy to replace just can get messy (see thread link above for Veeg33's brief description of fitting his or just ask). :D:thumbs:
  • Like 2
  • 3 weeks later...
