Boulderman1988 Posted March 14, 2016 Share Posted March 14, 2016 Hi, recently had my engine light come on and after diagnostic at cougar store the code is P0850 - park/neutral switch input circuit. Cougar store couldn't offer any other advice as they said this is normally for cars with auto gearboxes, my car is manual. Does anyone have any ideas? The light came on soon after having the box out so wondering if it's likely to be a switch damaged during the process - any relevant part numbers would be very much appreciated. Cheers Matt Quote Link to comment Share on other sites More sharing options...
MrMartinPGrant Posted March 14, 2016 Share Posted March 14, 2016 (edited) ive done a quick search and found others with the same problem on 370zs and other cars when they have took out the gear box, some are saying even manuals have this switch, something to do with the reverse light signal, and the cables were not plugged in right. have a look at this thread. http://www.the370z.c...switch-cel.html Edited March 14, 2016 by MrMartinPGrant 1 Quote Link to comment Share on other sites More sharing options...
bytespc Posted March 14, 2016 Share Posted March 14, 2016 The quote below is from Nissan Forums The neutral-safety switch is located on the bottom of the manual transmission, with a harness that runs to the connector on the top side of the transmission. It's a simple on-off switch that can be tested with an ohmmeter or continuity tester connected to the two pins in the harness connector and by shifting the trans in and out of gear. Rockauto.com has a picture of it on their site; search Airtex/Wells #1S5716. Replacement is pretty much put a drain bucket underneath the switch, unscrew the old one and install the new one, then top off the gear oil. 1 Quote Link to comment Share on other sites More sharing options...
Boulderman1988 Posted March 14, 2016 Author Share Posted March 14, 2016 (edited) Brilliant thanks for the responses, kept finding info about Altima gearboxes on my search so clearly you both have better googling skills than me! Should be able to get cracking with a fix at the weekend, hopefully just not plugged in properly rather than broken... Edited March 14, 2016 by Boulderman1988 Quote Link to comment Share on other sites More sharing options...
Mr_Gee_Dubz Posted April 13, 2016 Share Posted April 13, 2016 Did you manage to get this fixed? I've had the same thing happened to me, just bought the car a month ago and they replaced the clutch and flywheel before purchase Quote Link to comment Share on other sites More sharing options...
