Plenum Spacer
Fuli
Custom Anodised Plenum Spacers £170 (Last 3 remain no more ever again!)
http://www.350z-uk.c...re-ever-again!)
Is it a full bolt-on kit with every necessary parts to install it ? Does it's quality better than Motordyne's spacer or which one should I choose?
I had a wasso spacer in my first zed and then when I got my second one I got a motordyne. Must of had my motordyne in for a a month or so before swapping out for a wasso spacer.
Reason for this is the motordyne spacer is manufactured in 2 parts then stuck together which just wasn't for me. While the wasso ones are machines from one piece resulting in less possibility of leaking. All hardware comes with it and in a nice colour also
Thank You! I will take this wasso one! :)
Good choice
PM received and replied to Fuli, thanks Jeff for the promotions :)
An additional benefit over the motordyne is the fact mine are polished and anodised, therefore cleaning the spacer from engine oil/grime is far easier. The motordyne is laser cut and anodised grey. Although because their laser cutting is super rough, the dirt builds up and looks bloody horrible, and therefore cleaning it isn't easy! (That's if you're an engine bay cleaning type of guy) :lol:
  • Like 2
