SkylineV35 Posted March 4, 2016 Share Posted March 4, 2016 (edited) I have eibach anti rollbars and recently over the course of a year iv snapped 3 oem front drop links... my car is ownly lowered 25mm. So i have bought adjustable droplinks and set the sway bar so its horizontal and also hooked the link to the softest setting on rollbar.. however after a spirited drive iv noticed my frontend soaking up every pothole and dip on the road, to the point it shook the back and i could feel it losing traction. If i remember correctly with the oem ones the swaybar was sitting slightly higher around 20-25degrees. Iv read that to setup droplinks handtighten till it loads then tighten. But no matter how i set it up it was preloaded and couldnt hand adjust so just set them up the swaybar horizontal to the ground. After some reading on websites they say it should be 10-20degrees? Some say horizontal. What should i do? Edited March 4, 2016 by SkylineV35 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 4, 2016 Share Posted March 4, 2016 The drop links should be adjusted so that the link is at 90 degrees with no load. However this must be done with all 4 wheels evenly on the ground or on a platform ramp. 1 Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted March 4, 2016 Author Share Posted March 4, 2016 So droplinks 90 degrees to the swaybar? Ok il give that a go thanks! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 4, 2016 Share Posted March 4, 2016 Just to be clear, main drop link arm at 90 degrees to the knuckle ends of drop link. 2 Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted March 4, 2016 Share Posted March 4, 2016 I've still got to do my ones properly. Let me know how you get on (pics good) Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 4, 2016 Share Posted March 4, 2016 http://www.powergridinc.com/pdf/Powergrid%20Adj%20Links%20Installation%20Instructions.pdf 2 Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted March 4, 2016 Share Posted March 4, 2016 Cheers for that. Quote Link to comment Share on other sites More sharing options...
