atomic350z Posted March 3, 2016 Share Posted March 3, 2016 Thought I would just say to save people a lot of money, when changing your standard steering wheel or anything to do with steering column be very careful when moving, I changed my standard wheel for a tasty sabelt suede steering wheel and hkb boss but I managed to break what's known as the squib? Which has caused traction,abs and airbag lights to appear, this little item is £300 from Nissan and as far as I know you can only use a genuine Nissan part for this. So just a heads up be careful or get a professional. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
glrnet Posted March 3, 2016 Share Posted March 3, 2016 Have you tried Zmanalex? Quote Link to comment Share on other sites More sharing options...
atomic350z Posted March 3, 2016 Author Share Posted March 3, 2016 I don't know what or who that is mate ? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jonnymonno Posted March 3, 2016 Share Posted March 3, 2016 He's a trader on here Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 3, 2016 Share Posted March 3, 2016 On 03/03/2016 at 19:06, atomic350z said: I don't know what or who that is mate ? As Jonnymonno mentions he is a member trader on here. Link: http://www.350z-uk.com/user/9648-zmanalex/ Quote Link to comment Share on other sites More sharing options...
atomic350z Posted March 3, 2016 Author Share Posted March 3, 2016 Can't seem to see anything on that link ? Doesn't bring up zmanalex? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 3, 2016 Share Posted March 3, 2016 On 03/03/2016 at 19:33, atomic350z said: Can't seem to see anything on that link ? Doesn't bring up zmanalex? Sent from my iPhone using Tapatalk That link takes you to his username profile or at least it does on my laptop. Not sure why it wouldn't work for you though on your mobile. Try this instead ~ he posted in this thread: http://www.350z-uk.com/topic/106331-2006-front-tow-hook-cover/#entry1593904 Quote Link to comment Share on other sites More sharing options...
atomic350z Posted March 3, 2016 Author Share Posted March 3, 2016 Yep that worked thank you. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 3, 2016 Share Posted March 3, 2016 No probs. Quote Link to comment Share on other sites More sharing options...
Ekona Posted March 3, 2016 Share Posted March 3, 2016 Squib? Quote Link to comment Share on other sites More sharing options...
Ricey Posted March 3, 2016 Share Posted March 3, 2016 On 03/03/2016 at 20:03, Ekona said: Squib? Squib ring. Controls all sorts of stuff with the esp system I think Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ekona Posted March 3, 2016 Share Posted March 3, 2016 Gotcha. Never heard of that before! Quote Link to comment Share on other sites More sharing options...
cov350z Posted March 3, 2016 Share Posted March 3, 2016 guess he on about the spiral cable? Quote Link to comment Share on other sites More sharing options...
ZEUS Posted March 3, 2016 Share Posted March 3, 2016 Yeah I know it as the spiral cable too also heard it called the clock spring for some reason. 1 Quote Link to comment Share on other sites More sharing options...
Ekona Posted March 3, 2016 Share Posted March 3, 2016 Ah, clock spring is a term I've heard of. Quote Link to comment Share on other sites More sharing options...
veilside z Posted March 3, 2016 Share Posted March 3, 2016 Yes buddy, just send him a Pm. Quote Link to comment Share on other sites More sharing options...
retro_al Posted April 7, 2016 Share Posted April 7, 2016 How easy is it to sort the airbag light ? is it like seats and theres some wiring to put a resistor in ? Quote Link to comment Share on other sites More sharing options...
ZeppoJeff Posted April 7, 2016 Share Posted April 7, 2016 On 07/04/2016 at 22:29, retro_al said: How easy is it to sort the airbag light ? is it like seats and theres some wiring to put a resistor in ? Just a resistor that plugs into the connector Quote Link to comment Share on other sites More sharing options...
Jonny B Posted April 7, 2016 Share Posted April 7, 2016 So what does this 'squib' look like? Where is it located? And how do you avoid breaking it? I've got an aftermarket boss and wheel to fit soon, so any hints and tips would be appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
ZeppoJeff Posted April 7, 2016 Share Posted April 7, 2016 On 07/04/2016 at 22:37, Jonny B said: So what does this 'squib' look like? Where is it located? And how do you avoid breaking it? I've got an aftermarket boss and wheel to fit soon, so any hints and tips would be appreciated. Thanks You just have to careful really. So easy to swap wheel. Undo two torq screws to remove airbag. Unclip airbag and steering control connector. Undo the nut and remove wheel. Install new horn connector and resistor to connector. Install hub straight lining up plate behind into slot on hub. Screw down the nut. Install flat plate. Install wheel Connect horn to flat plate and wire from connector previously installed Push horn in place. Boom and you have a new aftermarket wheel installed Quote Link to comment Share on other sites More sharing options...
colesl4w Posted April 7, 2016 Share Posted April 7, 2016 Alex does a great deal on used spiral cables (if that's what a squib is) - £50! Quote Link to comment Share on other sites More sharing options...
