98duffa Posted March 3, 2016 Share Posted March 3, 2016 Hi all, any ideas what this could be its literally started on my drive home from work. Its not a knock or a clunk like a droplink would be but it clicks when I'm turning right either at slow speeds or normal. At idle it seems ok lock to lock Quote Link to comment Share on other sites More sharing options...
98duffa Posted March 3, 2016 Author Share Posted March 3, 2016 Its not a bearing noise and it doesn't increase with speed or droan Quote Link to comment Share on other sites More sharing options...
98duffa Posted March 4, 2016 Author Share Posted March 4, 2016 Anyone? Going to attempt to get it on a ramp later and hopefully find something and ill be sure to let you know the findings Quote Link to comment Share on other sites More sharing options...
gsexr Posted March 4, 2016 Share Posted March 4, 2016 Standard wheels or after market...... Seen a cracked after market wheel do this before... just a thought if nothing obvious pops up Quote Link to comment Share on other sites More sharing options...
Richf Posted March 4, 2016 Share Posted March 4, 2016 Do you have spacers fitted ? Quote Link to comment Share on other sites More sharing options...
blobbish Posted March 4, 2016 Share Posted March 4, 2016 if it does the same when turning left it could be an indicator 1 Quote Link to comment Share on other sites More sharing options...
-G- Posted March 4, 2016 Share Posted March 4, 2016 (edited) Where is the clicking coming from? If it was the front on a fwd car I'd say the CV joint, as its a rwd it'll be coming from the diff if its a similar issue. If it is the diff, topping up \ changing diff oil has been reported to silence it. Edited March 4, 2016 by -G- Quote Link to comment Share on other sites More sharing options...
ZeppoJeff Posted March 4, 2016 Share Posted March 4, 2016 I was going to say clicky axle but don't seem that way. Could always try greasing it up none the less and making sure it properly tightened onto the spline Quote Link to comment Share on other sites More sharing options...
98duffa Posted March 4, 2016 Author Share Posted March 4, 2016 Aftermarket rays track alloys with spacers. Seemed ok this morning in the wet but was very evident yesterday, forward or backwards from the front left area when turning right Quote Link to comment Share on other sites More sharing options...
98duffa Posted March 4, 2016 Author Share Posted March 4, 2016 Spacers have been on for a good 6 momths Quote Link to comment Share on other sites More sharing options...
