Rocker cover oil seal fix
-Bradders-
Right 2 of my oil seals were leaking as the engine is in bits i want to do the fix, however, theres no way im paying over £200 for a kit to do it when the seals cost a couple quid each and i already have new rocker gaskets and sealant.
Anyone know the size of the drill bit to cut the holes out?
Much appreciated.
Why don't you measure it yourself instead of relying on info. from another. ?
I have nothing to measure against unless its the same size as the stock one? i thought it was oversized?
Measure the new seal then.
