sonny Posted January 12, 2008 Share Posted January 12, 2008 Hi there, I have just used the powerboost product which is used to clean the intake system in my 350z and i followed the instructions carefully and have made sure that everything was replaced properly, since doing so the engine management light has come on! im rather worried about this, the car seems to be driving fine though!? i disconnected the battery to reset the ECU though this has made no difference? can anyone suggest anything please??? Quote Link to comment Share on other sites More sharing options...
mugwump Posted January 12, 2008 Share Posted January 12, 2008 what product did you use? What is it designed to do? There is also an ECU reset procedure that might help if the light has come on because of a glitch, if the problem is genuine it will come on again if there is something wrong. Disconnecting the battery wont help Quote Link to comment Share on other sites More sharing options...
captint Posted January 12, 2008 Share Posted January 12, 2008 It could be your oxygen sensor. I think the MAFF you could have knocked it or contanimated something Quote Link to comment Share on other sites More sharing options...
Sarnie Posted January 12, 2008 Share Posted January 12, 2008 It could be your oxygen sensor. I think the MAFF you could have knocked it or contanimated something Hello stranger, hows the business venture going? Quote Link to comment Share on other sites More sharing options...
captint Posted January 12, 2008 Share Posted January 12, 2008 Hello mate going pretty well, we have one site thats just launch, which is our UK to UK site. Check it out on www.personalshipper.com. Let me know what you think. The US and Hong Kong import sites are coming out in March. Along with a couple of other peaches. I'll set up an official post otherwise I'm going to get slapped for going off topic. Hows things with you, a you loving the Lambo (silly question really). Did you set up o your own in the end? Quote Link to comment Share on other sites More sharing options...
Sarnie Posted January 12, 2008 Share Posted January 12, 2008 Hello mate going pretty well, we have one site thats just launch, which is our UK to UK site. Check it out on www.personalshipper.com. Let me know what you think. The US and Hong Kong import sites are coming out in March. Along with a couple of other peaches. I'll set up an official post otherwise I'm going to get slapped for going off topic. Hows things with you, a you loving the Lambo (silly question really). Did you set up o your own in the end? Site looks good mate, very user friendly Yep, set up on my own in April, bought the G in July, been in love with it ever since Good to have you back Quote Link to comment Share on other sites More sharing options...
captint Posted January 12, 2008 Share Posted January 12, 2008 Cheers, well done on going it alone. I will officially be on alot more now Quote Link to comment Share on other sites More sharing options...
Sarnie Posted January 12, 2008 Share Posted January 12, 2008 Cheers, well done on going it alone. I will officially be on alot more now Good stuff Apologies for the OT stuff mods Quote Link to comment Share on other sites More sharing options...
Beavis Posted January 12, 2008 Share Posted January 12, 2008 No need to disconnect battery, guide here. http://www.350z-uk.com/forum/viewtopic.php?t=89 Quote Link to comment Share on other sites More sharing options...
mugwump Posted January 12, 2008 Share Posted January 12, 2008 Was it this you used? http://www.ecotekplc.com/pb_application.htm As mark says, could be the oxygen sensor, there are two on the Zed (one on each manifold bank). If one fails the ECU will ignore the duff one and will drive pretty normally. If you had done anything more serious the car would probably go into limp mode. Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted January 12, 2008 Share Posted January 12, 2008 Was it this you used? http://www.ecotekplc.com/pb_application.htm As mark says, could be the oxygen sensor, there are two on the Zed (one on each manifold bank). If one fails the ECU will ignore the duff one and will drive pretty normally. There are four oxygen sensors, a pair on each back, one being before the cat (for ECU fuelling) and one after (for emissions) - they are electronically linked in terms of faults too Reset your ECU and go from there Quote Link to comment Share on other sites More sharing options...
mugwump Posted January 12, 2008 Share Posted January 12, 2008 There are four oxygen sensors, a pair on each back, one being before the cat (for ECU fuelling) and one after (for emissions) - they are electronically linked in terms of faults too Reset your ECU and go from there You are indeed correct but any one failure will still put your fault light on but the car will drive normally. Do the reset as prescience says, if it comes on again you need to get it to the dealer (or a friendly mechanic with a diagnostic tool) to find out whats up. Quote Link to comment Share on other sites More sharing options...
sonny Posted January 13, 2008 Author Share Posted January 13, 2008 Thanks for the advice guys, I reset the ECU and all seems to be fine Quote Link to comment Share on other sites More sharing options...
