[SOLD]Invidia Decat Test Pipes VQ35DE
Snjur
Are these any good? And are they similar to HFC's?
Have no clue how do HFC's look alike. But these have served me well. With initial bolt on mods (intake,plenum,exhaust) i manage to get 306 bhp from starting 284.
If you plan to run also cat back system than you need to know this is a noisy set up
Sent from my SM-G850F using Tapatalk
They are not similar to HFC- high flow catalytic converter. They are Decats which means there is no catalyser. You get maximum flow through that but it means you won't pass MOT unless it's a "friendly" place.
The OEM catalyst is restrictive and so it the original y pipe design.
Couple of questions mate do you get any lights on from decats are they just a straight swap? And also do they smell ? I hear sometimes you get a smell from decats ?
Hmm. Not quite sure maybe some one will correct me but i think i did have lights on from O2 but i switch them of with Uprev or diagnostic tool can recall now exactly.
As for smell i didn't have any issue with that. All was like with Cat's
Did these cause your EML light to come on?
Thanks
Yup you get a EML light on byt depending of which tool you have available it can be turned on. If you have an Uprev or some diagnostics software it can be turned off
