Paul K Posted February 22, 2016 Share Posted February 22, 2016 The guy replacing my roof tells me the windows are not dropping enough when the door is opened to clear the roof edge. He suggested that the mechanism needs greasing Anyone experienced this before? I've had a search around but I can't seem to find anything ( the search function from the tapatalk app seems to bring up every post) I'll have another look round from my PC later Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Rook Posted February 22, 2016 Share Posted February 22, 2016 Same problem, following! Mine make the noise when you open the door and you can very gently push the window and it'll fall to the right place, then go back up again when closed, but it won't do it on its own. Quote Link to comment Share on other sites More sharing options...
Stutopia Posted February 23, 2016 Share Posted February 23, 2016 Have you done the re-learn? There's the easy one: Found it, tried it, sorted it. And for reference, here's what worked (with doors closed): Pull switch up (fully close window) Pull up & let go Pull up & hold for 3 seconds Push down and hold till window fully opens then let go Push down & hold for 3 seconds Pull up till window fully closed and let go Pull up and hold for 3 seconds Job done. This worked for both my driver and passenger windows. Then there's the one with the button press on the motor here http://www.350z-uk.com/index.php?showtopic=55900. 2 Quote Link to comment Share on other sites More sharing options...
Paul K Posted February 23, 2016 Author Share Posted February 23, 2016 (edited) thanks Stu, i'll give the simple one a go first... If i've got to pull the door cards off to do the motor reset...i'll relube the mech at the same time Edited February 23, 2016 by Paul K Quote Link to comment Share on other sites More sharing options...
