GeorgeW Posted February 19, 2016 Share Posted February 19, 2016 (edited) I fancy giving this a go, since my car is starting to look devilish, it would look great on photos. This is a 2004 zed, so not a facelift if that makes much of a difference to the headlights The plan is to have it linked up to the third switch next to the heated seat switches. questions 1. does anyone have a DIY for doing it? I have internet searched but havent seen anything about wiring up to switches. 2. do the lights need to come out or is it possible to do on the car? all the headlight needs is a little hole drilled, so how easy is it to get to? 3. can you buy a switch to use where the blank is, or can this be used and its just held static at the moment? Thanks George Edited February 19, 2016 by GeorgeW Quote Link to comment Share on other sites More sharing options...
ZeppoJeff Posted February 19, 2016 Share Posted February 19, 2016 Mine has the iron man mod done to mine before I got them but I've an idea. Basically you are going to have to take the lights off ur car, bake them, split them, dismantle the internals, install a strip of less around the projectors then reassemble. Obviously not going to be simple but that gives you an idea. It's up to you how u wire them up though as you might want to run its own live off something or tap into the sidelights. Hope that helps you. Quote Link to comment Share on other sites More sharing options...
GeorgeW Posted February 19, 2016 Author Share Posted February 19, 2016 ok thanks for that, its a start. the idea is just to wire it up to the switch in the car next to the heated seats - so it is seperate to the actual cars lights. On photos on google of the MOD to 06+ cars they just use a single red LED drilled into a little hole in the projector. I was wondering if this is able to be done without dismantling the headlight unit? Quote Link to comment Share on other sites More sharing options...
ZeppoJeff Posted February 19, 2016 Share Posted February 19, 2016 I think for a uniformed light all through the projector it would be better with led strips and easier for mounting also. Also if u go for led strip you could change the little colour if that's something ur into. Have it a white light for driving then any other when off road obviously ;P Personal opinion though. Good luck with what you decide. Quote Link to comment Share on other sites More sharing options...
zebedy Posted February 19, 2016 Share Posted February 19, 2016 The LEDs needs to be behind the concave glass thats infront of the projector and two holes drilled just behind. You will need to remove the headlamp and split it in an oven to do this mod. Quote Link to comment Share on other sites More sharing options...
Hodaka Posted February 19, 2016 Share Posted February 19, 2016 I've been looking into fiddling with my headlights recently as well actually. This post might help in terms of placement of the LED if you're going for a single LED set up. I only glanced over it before, but the thread in general may be useful: http://my350z.com/forum/exterior-and-interior/399820-03-05-headlight-mod-9.html#post7973773 Also I haven't read this in full and it's on a 06 headlight as well, but there maybe some useful info on this thread: http://my350z.com/forum/body-interior-exterior-and-lighting-diy/545974-06-headlight-mods-the-thread-of-all-threads-many-pix.html Been practicing making halos as well. Bought the stuff prior to realising they're quite cheap to buy online. My first attempt (dimmer & messier) and second attempt below. As I say, just practice so it's messy wiring / haven't measured to size / no reflective backing etc... etc... Quote Link to comment Share on other sites More sharing options...
Payco Posted February 19, 2016 Share Posted February 19, 2016 Why not just send them away to be done properly ?. Quote Link to comment Share on other sites More sharing options...
Hodaka Posted February 19, 2016 Share Posted February 19, 2016 On 19/02/2016 at 13:24, Payco said: Why not just send them away to be done properly ?. We be poor Martin Plus personally I enjoy DIY anyway 2 Quote Link to comment Share on other sites More sharing options...
ZeppoJeff Posted February 19, 2016 Share Posted February 19, 2016 I'd be using a strip of led rather than a ring as the light output will be greater unless your looking for the Angel eye look. Quote Link to comment Share on other sites More sharing options...
Andymac183 Posted February 19, 2016 Share Posted February 19, 2016 Just curious where I would send mine to be done...? Quote Link to comment Share on other sites More sharing options...
Payco Posted February 19, 2016 Share Posted February 19, 2016 Headlightretrofits Quote Link to comment Share on other sites More sharing options...
GeorgeW Posted February 19, 2016 Author Share Posted February 19, 2016 I didnt realise you could send them away to be done, I might price is up. But im guessing it wont be cheap! Quote Link to comment Share on other sites More sharing options...
ZeppoJeff Posted February 19, 2016 Share Posted February 19, 2016 On 19/02/2016 at 15:28, GeorgeW said: I didnt realise you could send them away to be done, I might price is up. But im guessing it wont be cheap! Speak to davectr as I think he got his done there Quote Link to comment Share on other sites More sharing options...
Davectr Posted February 19, 2016 Share Posted February 19, 2016 You'd need to speak to Dominik who runs Headlightretrofits for an accurate price, but probably in the region of £250-300 Quote Link to comment Share on other sites More sharing options...
