Lindsey Posted February 19, 2016 Share Posted February 19, 2016 Hi I am new on here. I cannot find anyone who can help fix my 350z soft top. I live in UK .... please please help. I love my car to bits but cannot drive as soft top not fully closed. (( Quote Link to comment Share on other sites More sharing options...
Paul K Posted February 19, 2016 Share Posted February 19, 2016 Hi Lindsay Has the hood just stopped functioning Can it open fully? Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Lindsey Posted February 19, 2016 Author Share Posted February 19, 2016 It did nut am afraid to try as it is in semi closed. Had new hood fitted as holes and rips in old. Seen so many comments about cold. Can you help Quote Link to comment Share on other sites More sharing options...
Lindsey Posted February 19, 2016 Author Share Posted February 19, 2016 I am absolutely desolate ( Quote Link to comment Share on other sites More sharing options...
Paul K Posted February 19, 2016 Share Posted February 19, 2016 If you can , get the car running, crank the heating up really high to get the roof warm, even bring an additional fan heater if you are able. make sure everything is warm , then try to open hood fully then try closing again. Do not try to force it by hand as you will bend something. 1 Quote Link to comment Share on other sites More sharing options...
Floydbax Posted February 19, 2016 Share Posted February 19, 2016 I think the heating method only works for the Vinyl OEM roof which gets stiff as it gets colder, 'though it's worth a try. Lindsey, make sure the cars running so you have full electric ampage, make sure the car's out of gear and foot on the footbrake, then push the roof switch down to try to open the roof fully. If it only go's a little then stop and try the switch the other way. Keep doing this back and forth and it ought to eventually go all the way up and down. I wouldn't try to force it manually just use the motors. Hope it works 1 Quote Link to comment Share on other sites More sharing options...
Lindsey Posted February 19, 2016 Author Share Posted February 19, 2016 Thank you both ... Quote Link to comment Share on other sites More sharing options...
Paul K Posted February 19, 2016 Share Posted February 19, 2016 (edited) good point about the OEM vinyl roof did you have mohair or vinyl fitted Lindsey. i still think a bit of warmth will help, even the lubricant on all the joints will move a bit better, but as Floydbax say, just keep going through the open/close sequence. hope it gets sorted Edited February 19, 2016 by Paul K 1 Quote Link to comment Share on other sites More sharing options...
Lindsey Posted February 19, 2016 Author Share Posted February 19, 2016 Quick question ... it is really cold today should I try now Quote Link to comment Share on other sites More sharing options...
Lindsey Posted February 19, 2016 Author Share Posted February 19, 2016 Btw ... I had Nissan original hood replacement .. I believe vinyl Quote Link to comment Share on other sites More sharing options...
JetSet Posted February 19, 2016 Share Posted February 19, 2016 The open/close method should work and it'll help if you spray some WD 40 on as many of the joints that you can find. Nissan say the minimum operating temperature for the hood is 5 degrees C, from experience I'd say closer to 10 degrees is more like it. Pete Quote Link to comment Share on other sites More sharing options...
Paul K Posted February 19, 2016 Share Posted February 19, 2016 (edited) Btw ... I had Nissan original hood replacement .. I believe vinyl if you can , get it parked in the sun (depending where you are, obviously....its quite sunny in kent at the moment) and get the heater on full blast, and as Jetset suggests, a bit of spray lube on as many joints as you can find won't hurt Edited February 19, 2016 by Paul K Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 19, 2016 Share Posted February 19, 2016 (edited) Best to get it up to temperature before roof operation is attempted. As Pete has said, minimum of 5 degrees C however operation will be easier on the motors, in particular 5th bow if 10 degrees C If major surgery required then this may help: http://pdf.textfiles...upe/2005/rf.pdf Alex, Edited February 19, 2016 by ZMANALEX Quote Link to comment Share on other sites More sharing options...
zebedy Posted February 19, 2016 Share Posted February 19, 2016 Can you tell me what exactly is happening. Ive fixed four of these now and consider my self the master. lol Let me know whats going on from the moment you sit down to the moment it stops. Describe everything to me as I may be able to help. 1 Quote Link to comment Share on other sites More sharing options...
Lindsey Posted February 19, 2016 Author Share Posted February 19, 2016 I have had 350 6 years and never had this issue. When I go through routine of opening soft top it goes fown all but one inch. When I try to close it, it will stay open about an inch at the back. Ihad a new roof fitted as it had tears and rips and thought it may solve this problem. I am gutted... please if you can do help me Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 19, 2016 Share Posted February 19, 2016 Had the same issue about 2 weeks ago. It was simply lack of use and a temperature issue. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted February 19, 2016 Share Posted February 19, 2016 Sorry to hear about your soft top problems but welcome aboard Lindsey. Some more related topics: http://www.350z-uk.com/topic/30517-roadster-roof-problems-wont-fully-go-down/ http://www.350z-uk.com/topic/53888-convertible-roof-problems-opening/ http://www.350z-uk.com/topic/17101-problems-with-a-roadster-roof-mechanism/ http://www.350z-uk.com/topic/56205-soft-top-roof-sticking-when-opening/ http://www.350z-uk.com/topic/64015-soft-top-wont-go-down/ http://www.350z-uk.com/topic/87180-convertible-issues-5th-bow-motor/ http://www.350z-uk.com/topic/104602-sticking-convertible-roof/ Quote Link to comment Share on other sites More sharing options...
jimmy.farrow7 Posted February 19, 2016 Share Posted February 19, 2016 I have a coupe and not a soft top so it may be a silly question but is there anyway something can be blocking it Quote Link to comment Share on other sites More sharing options...
