Aerial Snapped off!
Andymac183
Got a bit too carried away with the hot foam brush and snapped off my stubby - I'm wondering if there's anything I can do with the remainder as it looks like there isn't enough exposed thread to screw anything into anymore - can anyone tell me if the picture below looks like I'll need a new mount? Or can I remove the remainder somehow?
it looks like you might just be able to get some pliers on the end of that and unscrew whats still left in the mount. some penetrating oil an hour or two before will help.
failing that, when I snapped my cheap ebay aerial, I very carefully drilled out what was left in there, and left enough thread intact to screw in a new, better Honda RDX aerial. buy cheap buy twice and all that!
on the plus side, you can't make it any worse than it is already (unless your drill bit slips and you accidentally drill a hole in your wing)
Edited by brillomaster
  • Like 2
