True dual exhausts better for breathing and power
Luke350
Found no significant difference after fitting invidia dual and cobra HFCs,s
Upreved at Tdi north and dyno read 333 b.h.p.. Only noticable difference is that the engine revs higher now.
This on HR?
Sasha Anis back to back tested a true dual vs a single and the dual murdered the power figure.
Problem is that na relies on the scavenging effect of each pulse (creates a vacuum behind it when the velocity is correct) as that helps pull the exhaust gasses out of the next cylinder duals need a REALLY good x pipe to keep this happening, and without it you lose a lot of power over a good single. H pipes are no good as they just dont transfer that vavuum well enough between the banks (v8 boys in america have found this as well, h pipe is lower power than x pipe)
