SherlockH Posted February 12, 2016 Share Posted February 12, 2016 can anyone link me a guide on removing my front left wing? Just want to know if the front bumper has to come off to replace/remove it? I tried google to no avail Quote Link to comment Share on other sites More sharing options...
jimmykool111 Posted February 12, 2016 Share Posted February 12, 2016 (edited) Also interested in this... Edited February 12, 2016 by jimmykool111 Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted February 12, 2016 Share Posted February 12, 2016 Hi guys, you do not need to remove the bumper but its easier if you remove the front wheels, there is 3 bolts to undo bumper to wing, you can pull the arch liner away and get to these bolts, Remove the screws that hold the arch liner to the wing, there are a couple of push type clips at the bottom to remove. Remove skirt it just pulls away, Remove bolts from the top of the wing under the bonnet, and then just follow the wing and you will see the other bolts to remove, including 2 at the bottom of the wing and one near the top hinge, Unplug the indicator Be careful not to scratch the headlight on removal and refitting Basically from the top of my head that's it 2 Quote Link to comment Share on other sites More sharing options...
jimmykool111 Posted February 15, 2016 Share Posted February 15, 2016 Hi guys, you do not need to remove the bumper but its easier if you remove the front wheels, there is 3 bolts to undo bumper to wing, you can pull the arch liner away and get to these bolts, Remove the screws that hold the arch liner to the wing, there are a couple of push type clips at the bottom to remove. Remove skirt it just pulls away, Remove bolts from the top of the wing under the bonnet, and then just follow the wing and you will see the other bolts to remove, including 2 at the bottom of the wing and one near the top hinge, Unplug the indicator Be careful not to scratch the headlight on removal and refitting Basically from the top of my head that's it Cheers dude! Thanks for the help Quote Link to comment Share on other sites More sharing options...
