GeorgeW Posted February 11, 2016 Share Posted February 11, 2016 Now before I start, I do want to point out that: 1. yes I have searched the forum and internet for answers, but nothing seems to help 2. yes I know this should be an easy job, but: 3. No I haven't had much sleep due to illness, and a new baby! SO! I want to remove the plenum and throttle body for painting. So I took the strut off, then the plastic cover, then onto the plenum bolts. I worked my way around getting all that looked like they were holding them down. I gathered that it was just a case of removing the bolts, but for some reason it isn't budging! I am either missing extra bolts or its stuck and needs prying off. Though I haven't seen anyone mention this so didn't want to try it and ruin something! Any help would be great Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 11, 2016 Share Posted February 11, 2016 Should just pop off once all the bolts are removed, however may require very, very, gentle persuasion to break the seal. My guess is that you have missed a bolt. Quote Link to comment Share on other sites More sharing options...
GeorgeW Posted February 11, 2016 Author Share Posted February 11, 2016 (edited) yes maybe, but Im sure I got them all around the sides and front, and thought even if one was still on the back, it would still wiggle the front up and down! maybe it is that the seal needs breaking. what about removing the throttle body, I see people removing both at once, but then on the internet people say to remove the plenum first. if so, how easy is that to do? Edited February 11, 2016 by GeorgeW Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 11, 2016 Share Posted February 11, 2016 There are 18 bolts in all. 11 around the perimeter of the plenum. If you've only found 10, then there's your answer. Don't forget number 9, whilst not obvious can be missed. Also number 8, you need to reach right over the plenum. 2 Quote Link to comment Share on other sites More sharing options...
GeorgeW Posted February 11, 2016 Author Share Posted February 11, 2016 Thanks wasso, maybe it was number 9 that was doing it. Is there a drawing for the throttle body removal as well? Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 11, 2016 Share Posted February 11, 2016 Also you'll have hoses attached to the plenum. If I recall. One to the left, easy to spot Behind the Throttle Body Then a final one underneath the Throttle Body, which points towards the air intake tube The last in that list is the hardest to reach under and remove. Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 11, 2016 Share Posted February 11, 2016 Thanks wasso, maybe it was number 9 that was doing it. Is there a drawing for the throttle body removal as well? 4 Allen bolts hold the TB in place. There's an electrical plug to the right hand side, of the TB which must be removed. That's it really. Quote Link to comment Share on other sites More sharing options...
hairyman68 Posted February 11, 2016 Share Posted February 11, 2016 Yes as zmanalex said... my was a tight fit...needed a lot of persuading , but again check for missed bolts... there are 11 or 12 if I remember. ...maybe look at a supplier that should tell you how many supplied bolts... Quote Link to comment Share on other sites More sharing options...
GeorgeW Posted February 11, 2016 Author Share Posted February 11, 2016 ok great, yes I found two pipes, never got to the one under it. A few places on the internet say to disconnect the battery before removing the TB as well or it will screw everything up - true or false? Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 11, 2016 Share Posted February 11, 2016 Recommended yes, but I never have. Disconnect the TB via the plug. Just go careful with the TB butterfly. Extreme care is required not to move the butterfly as it's electronically set. It would be safe to undertake the TB reset procedure once you've done what you need, if in doubt of moving the butterfly. http://my350z.com/forum/maintenance-and-repair/371324-how-do-i-do-the-throttle-body-relearn-procedure.html Quote Link to comment Share on other sites More sharing options...
GeorgeW Posted February 11, 2016 Author Share Posted February 11, 2016 ok nice one. I only want to spray the outside so hopefully don't desturb the butterfly when masking up Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 11, 2016 Share Posted February 11, 2016 ok nice one. I only want to spray the outside so hopefully don't desturb the butterfly when masking up You'll be fine, once it's taped both sides it will give it some nice protection. Don't drop the TB for god sake! Quote Link to comment Share on other sites More sharing options...
GeorgeW Posted February 11, 2016 Author Share Posted February 11, 2016 I don't tend to drop things, but not you've said that I'll bloody drop it down a black hole. My carbon hood will be going on at the weekend if we don't get TOO much snow, so I will give this a go then. Cheers for the help so far 1 Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 11, 2016 Share Posted February 11, 2016 No worries Quote Link to comment Share on other sites More sharing options...
Payco Posted February 11, 2016 Share Posted February 11, 2016 Great guide from Wasso. Have removed my plenum and throttle body a few times now and its not that difficult if you take your time. Use your mobile to take some photos as you go if you are not sure of where things go back etc. Be careful not to damage the gasket too when you remove the upper plenum. Don't forget to put the centre plenum bolts back in the right order too and torque them. They are different lengths too so make sure you make a note of which lengths go where. Good luck, Quote Link to comment Share on other sites More sharing options...
GeorgeW Posted February 11, 2016 Author Share Posted February 11, 2016 Yes I found that out last night, but eventually worked out which ones go where. Thats the type of tip which saves alot of hassle when someone tries something for the first time. It may seem obvious when you have done it, but I had no idea they would have different length bolts! Quote Link to comment Share on other sites More sharing options...
Payco Posted February 11, 2016 Share Posted February 11, 2016 (edited) I was a bit anal first time a made a diagram on a thick bit of card and then pushed each bolt into the cardboard diagram when I took them out so I knew exactly where they had to go back to. Sick of always having one bolt left on previous projects !!. Seasoned pro now, but novice at the start. Wasso helped me loads in my first year of ownership and modding. He's a top man. Edited February 11, 2016 by Payco 2 Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 11, 2016 Share Posted February 11, 2016 Yes I found that out last night, but eventually worked out which ones go where. Thats the type of tip which saves alot of hassle when someone tries something for the first time. It may seem obvious when you have done it, but I had no idea they would have different length bolts! If you use the plenum bolt guide above the following applies: Red - Long Yellow - Medium Green - Small Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 11, 2016 Share Posted February 11, 2016 I was a bit anal first time a made a diagram on a thick bit of card and then pushed each bolt into the cardboard diagram when I took them out so I knew exactly where they had to go back to. Sick of always having one bolt left on previous projects !!. Seasoned pro now, but novice at the start. Wasso helped me loads in my first year of ownership and modding. He's a top man. Sorry about that Quote Link to comment Share on other sites More sharing options...
Payco Posted February 11, 2016 Share Posted February 11, 2016 Ian. Fond memories of driving up to meet you to pick up my polished plenum, strut bar etc and then several months later speaking at 11pm on a Friday night after you spotted an ARC catch can for me in Texas !!. After seeing Suzie I was hooked on modding my z. You have a lot to answer for mate. Quote Link to comment Share on other sites More sharing options...
GeorgeW Posted February 11, 2016 Author Share Posted February 11, 2016 Now thats man love right there! Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 11, 2016 Share Posted February 11, 2016 Ian. Fond memories of driving up to meet you to pick up my polished plenum, strut bar etc and then several months later speaking at 11pm on a Friday night after you spotted an ARC catch can for me in Texas !!. After seeing Suzie I was hooked on modding my z. You have a lot to answer for mate. Now thats man love right there! Apologies on both accounts To be honest if you put my car and Payco's together in a carpark the only difference is the colour (bar a few mods). Although Payco has now made some radical changes to his bay. Was a pleasure to help anyone else get the Zeditus bug. It's painless until you click "Add to Basket"!!! 2 Quote Link to comment Share on other sites More sharing options...
GeorgeW Posted February 11, 2016 Author Share Posted February 11, 2016 pays off though. Luurrrvely looking zeds 1 Quote Link to comment Share on other sites More sharing options...
veilside z Posted February 12, 2016 Share Posted February 12, 2016 Glad all went well for you buddy. Quote Link to comment Share on other sites More sharing options...
gsexr Posted February 12, 2016 Share Posted February 12, 2016 Feeling the luv in the room Quote Link to comment Share on other sites More sharing options...
