RyanT Posted February 5, 2016 Share Posted February 5, 2016 (edited) Ok I'm almost at the stage where I want to set the car alight! I was removing my radio the other day, and one of the white connectors on the back came apart, meaning all the wires came loose. Not a problem you think? Just pop them back in? Well unfortunately not, I found a wiring diagram and did just that and the bloody thing won't turn on! Note, that this connector diagram is as though you are looking at the connector head on? (I confirmed this by looking at the diagram in relation to other connectors which hadn't fallen apart! I've checked all interior fuses here: All seem fine. Plus I've got the voltmeter out, and checked the wires on that connector and there's voltage (when using the aerial connector as an earth) where you'd expect. So it's definitely getting power. Plus the illumination works when you turn on the lights! On top of all this, I even connected the wires directly to the pins, just to make sure the block itself wasn't causing issue. Anyone that can help and get this thing working will earn some beer tokens from me! Cheers! Edited February 5, 2016 by RyanT Quote Link to comment Share on other sites More sharing options...
richard.hezlett Posted February 5, 2016 Share Posted February 5, 2016 With your meter are u getting 12 volts between pins 9 ( grey ) and 10 ( pink/black ). The supply for the illumination comes in on a different pin ( pin 8 ). Quote Link to comment Share on other sites More sharing options...
RyanT Posted February 5, 2016 Author Share Posted February 5, 2016 (edited) With your meter are u getting 12 volts between pins 9 ( grey ) and 10 ( pink/black ). The supply for the illumination comes in on a different pin ( pin 8 ). Hi Rich, Just back out in the car now, nothing registering between pins 9 & 10! Edit: the only connectors I'm getting a voltage reading from now is between pin 8 (red blue) and the aerial connector. Pin 8 and the grey earth, pin 9 does nothing either. Edited February 5, 2016 by RyanT Quote Link to comment Share on other sites More sharing options...
richard.hezlett Posted February 5, 2016 Share Posted February 5, 2016 Pin 9 is a common earth for pins 5 ( electrical ariel ), 8 ( backup for saved info ), 9 ( illumination when your lights are on ) and pin 10 ( main supply to Bose unit ). Your problem is no supply on this pin ( pin 10 ). Check pin is sitting correctly in plug ( is pushed in fully )and the fuse for this supply is not blown. There are 2 other fuse boxes in the engine bay at the bulkhead behind the battery. Quote Link to comment Share on other sites More sharing options...
RyanT Posted February 6, 2016 Author Share Posted February 6, 2016 Thanks again Richard for the help. The issue is now fixed, essentially the radio fuse in the fuse box near the battery was blown. Replaced this, still didn't work. Noticed that dials weren't lighting up / electric mirrors weren't working - So replaced the 'mirror' fuse in the interior fuse box and now all is working. Hurrah! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
richard.hezlett Posted February 6, 2016 Share Posted February 6, 2016 Glad you are sorted. That's the beauty of this forum,everybody helps everybody else. 2 Quote Link to comment Share on other sites More sharing options...
russyb Posted February 21, 2016 Share Posted February 21, 2016 yay all sorted, I can hear Justin now lmfao cheers for all the info guys hopefully it may help someone else one day Quote Link to comment Share on other sites More sharing options...
