screen wash motor replacement
horus1970
I need to take my zed for its mot and all seems good apart from the windscreen washer isn't working and I cant even hear anything when I press it ,
so my question is will any motor fit,, my car is a jdm anniversary model 2005, ive just ordered single outlet
Just replaced mine. I have an 03 JDM. They are exactly the same as a UK car. There are two pumps and they are different for the front and rear, but if you only need the front You can get them on eBay for between £5 and £8.
To get to it just remove the arch liner on the drivers side front. The pump that does the windscreen will be the one that is the closest to you. Just pull it out, then remove the connector. Should take you around 10 mins.
Edited by Rob332
