OZ challege HLT black
G1en
Simple question. Would these wheels fit the zed
I am hopefully picking up my zed next week and looking at new wheels. These are expensive but lightweight and i think would look great on the black zed
They are 18" only available
8.5 wide for front 10" for rear
Offset 20 front and 25 rear
Thos seems spot on but centre bore is something like 63mm dont know if this is correct?
It says they are made for BMW M3 and 6 nut version for Dodge Viper.
Would they work?
You would need to check spoke design to see if they clear Brembos, centre bore is 66.1so if your right on Oz centre bore that may create a problem.
Also it depends on your definition of light, they are minimum 4lbs heavier than rays which is considerable in unsprung mass.
The wheels on the car are the special edition 5 spoke that were on the GT4 edition
Do you know how these compare weight wise? If lighter may look to get these refurbed in different colour
Gt4 wheels are a couple of pounds heavier, but depends on what size Oz you go for, they are 22 to 24lbs, really isnt lightweight, but neither are the Gt4.
