Code P1147
bytespc
Hi guys as you know I first had my eml light up a few weeks ago on a roundabout turning left after giving the car some welly to escape a dodgy situation, anyway long story short it lit again tonight on the same roundabout in the wet, so plugged in the reader got the code and reset the eml, this has only started happening after I had my Cobra Exhaust fitted , so my question is should I get my independent to check the connection is firm and or is it safe to leave it until the car is serviced at Horsham Dev in July and get them to replace with a second hand or new part then ?
Thanks in advance
Someone more experienced will come a long I'm sure.
However, off the top of my head this is the o2 sensor. Mine came on a couple weeks ago, reset and its been fine.
From what I was reading its just the sensor which will be faulty which is around £60-90 to fix.
Totally fine to drive the car IMO.
