3mm spacer
Jack wellZ
Hi guys looking for a pair of 3mm spacers for my JR11 wheels as they are rubbing the front brembo callipers 😭 3mm should be enough I hope :/ trying to find a good branded set, don't mind if used. :)
Thanks
EDIT -
been told i can put a 10mm hub on and should also all be fine so if anyone has a good 10mm for sale that is probably best
Edited by Jack wellZ
Halfords do 3mm spacers:
http://www.halfords....3mm-4-or-5-stud
A word of warning though. I bought a set to use with 20mm spacers on the 370 but not longer after they were found to be responsible for disc distortion due to the soft alloy compressing unevenly. So I changed the 20mm spacers to 25mm spacers and all good again, although I appreciate you are not using other spacers. So just suggesting you be a bit careful in your choice so as not to cause another problem. ;)
