350z Gear and Diff Oil
Tyler
Afternoon,
After looking at a few very useful threads regarding Oil I'm about to order these for my gearbox and Diff. I've recently done my engine oli so no need to do that again. Few questions though if I may.
Do I need more that 3 litres for the gearbox? Apparently Nissan say 2.93 but some people have said 3.3 is that true or will I be ok?
Also would anyone recommend other oils over these or would they suffice?
Many thanks
Tyler
Bit more expensive Tyler but I used genuine Nissan oils in my 350 when I did my gearbox & differential oil. 3 Litres AFAIK should be enough for the gearbox & 2 litres for the diff.
Gearbox oil (includes Moly Slip): http://www.h-dev.co.uk/product_info.php?cPath=78_169_293_1418&products_id=25501
Diff oil: http://www.h-dev.co.uk/product_info.php?cPath=78_169_293_1418&products_id=25506
Fyi if you're doing the diff yourself make sure you can get the fill plug undone as well as the drain plug before you empty the oil. :thumbs:
Gearbox oil (includes Moly Slip): http://www.h-dev.co....oducts_id=25501
Diff oil: http://www.h-dev.co....oducts_id=25506
Excellent thanks, I've read a lot of good review with the OEM and Moly slip so I might take your advice.
I'll order these now as I'm doing them next week.
Will take note of the fill plug lol
Thanks
