Bilstein b6 / tein springs . As new !
Bodyboarder81
Have a full set of Bilstein b6 dampers ( 4 in total ) and tein s tech springs . Covered a massive 3k on my car ! These are a absolute brilliant set up for the zed . Many have this set up on the forum with great reviews . I also have a set of rear purch/ bump stops that have been cut down my 10mm to even up the ride height .
The bilstiens are £450 new
Tein springs are £155 new
After £450 for both . Collected from Southampton .
These will be off the car in 3 weeks time . They will be fully cleaned and a coat of acf-50 applied to Protect them for the new owner .
The teins drop the car about 17mm front and 14mm rear . The spring perch mod brings the back in line with the front . The bilstiens are designed to be used with standard springs and up to a 30mm drop in height . Making these the perfect combo together .
I'll get a pic of my car , as they are still on it at the moment .
Are they front and rear true coilovers or are you still going to use the inboard spring buckets ?
Alan
Still uses the spring bucket . Im personally not keen on true coilover set up for the rear as its not how nissan designed it . Although lots run them with no issues .
Oo tempting, was thinking about a drop just the other day.
Still not got around to fitting the Milltek I bought off you yet tho. Not sure the missus would appreciate yet more car parts stacked up in the dining room.
Do it ! You have seen the quality of the parts I've sold first hand ... These are no different :)
This is how they look
Edited by Bodyboarder81
How's the ride compared to stock? Don't really want to be crashing about all over the place, the Zed is my daily.
It's a very very good ride quality . I run 19" wheels and think it's a really good quality ride . Not crashy at all , just firm and controlled. Stu and others run this set up , so by all means pm him to get an unbiased view .
As others know I only buy quality parts and I believe this spring/ damper combo is the best out there , other than going high end coilovers .
Infact if anybody wants me to take them out this coming week i can do so , as im dropping the zed to H-dev on friday . Try before you buy :)
Swing by mine if you do dude ;)
Sent from my D6503 using Tapatalk
