Bodyboarder81 Posted January 11, 2016 Share Posted January 11, 2016 Hi all , Bought some 2nd hand rear adjustable eibach/spc camber arms ...... So this will get my camber in line . Do I also need some toe bolts/arms? Also what about rear traction control links? Getting very confused as to what I'll need to be honest ! Car will be lowered around 20-30 mm max Will the front be ok without upper camber arms ? Thanks Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 11, 2016 Share Posted January 11, 2016 You will probably require the rear toe bolts. Rear traction arms not really required. Front adjustable camber arms will be required if the camber is out with spec. and you won't know this until you have the car on the 4 wheel alignment machine, however you should be within spec at a drop of circa 20, but 30 will be pushing it. Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted January 11, 2016 Share Posted January 11, 2016 Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted January 11, 2016 Author Share Posted January 11, 2016 Ok thanks Alex ,I'll order some toe bolts What's these lock out bolts that I keep seeing/ reading about ? Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted January 11, 2016 Share Posted January 11, 2016 That's where I ended up mate with stock arms My back tyres are low now anyway so I'll see how the wear is and make a decision on arms Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted January 11, 2016 Author Share Posted January 11, 2016 That's where I ended up mate with stock arms My back tyres are low now anyway so I'll see how the wear is and make a decision on arms But you're running stock height right Nic? Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted January 11, 2016 Share Posted January 11, 2016 Well he said so but I thought there was a min drop on kW? ?? Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted January 11, 2016 Share Posted January 11, 2016 It certainly look like when I dropped it off lol Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted January 11, 2016 Share Posted January 11, 2016 Ok thanks Alex ,I'll order some toe bolts What's these lock out bolts that I keep seeing/ reading about ? The lock out bolts and washers are to stop the rear arms from moving which would effect your geometry settings. Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted January 11, 2016 Author Share Posted January 11, 2016 Ok thanks Alex ,I'll order some toe bolts What's these lock out bolts that I keep seeing/ reading about ? The lock out bolts and washers are to stop the rear arms from moving which would effect your geometry settings. Worth it for a road car? Or just BS ? Quote Link to comment Share on other sites More sharing options...
djtimo Posted January 11, 2016 Share Posted January 11, 2016 You need toe bolts or just by toe arms and be done with it. I needed them and I'm not low at all. Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted January 11, 2016 Share Posted January 11, 2016 Josh, you adjust the geometry settings from the arms, unlike the OEM ones which you adjust from the oval bolt. So with the adjustable arms you need to be able to lock it in place where the oval bolt is, therefore you use a square one / locking nut Hope it makes sense. 1 Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted January 11, 2016 Author Share Posted January 11, 2016 You need toe bolts or just by toe arms and be done with it. I needed them and I'm not low at all. Are the toe arms the ones that the rear springs sit into ? Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted January 11, 2016 Author Share Posted January 11, 2016 Josh, you adjust the geometry settings from the arms, unlike the OEM ones which you adjust from the oval bolt. So with the adjustable arms you need to be able to lock it in place where the oval bolt is, therefore you use a square one / locking nut Hope it makes sense. Yes ...... For once you make complete sense ! Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted January 11, 2016 Share Posted January 11, 2016 You need toe bolts or just by toe arms and be done with it. I needed them and I'm not low at all. Are the toe arms the ones that the rear springs sit into ? No, these are midlinks / spring buckets Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted January 11, 2016 Share Posted January 11, 2016 Josh, you adjust the geometry settings from the arms, unlike the OEM ones which you adjust from the oval bolt. So with the adjustable arms you need to be able to lock it in place where the oval bolt is, therefore you use a square one / locking nut Hope it makes sense. Yes ...... For once you make complete sense ! I know, bloody foreigners! :lol: 1 Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted January 11, 2016 Author Share Posted January 11, 2016 You need toe bolts or just by toe arms and be done with it. I needed them and I'm not low at all. Are the toe arms the ones that the rear springs sit into ? No, these are midlinks / spring buckets Ah right ! Getting a picture of it all now !! So i need toe bolts( or toe arms ) and lock out kit ? Pm me you slovakian turnip Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted January 11, 2016 Share Posted January 11, 2016 PMSL! Visit http://www.torqen.uk you lazy sod! It looks awesome on your iPad Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted January 11, 2016 Author Share Posted January 11, 2016 It does indeed ...... But i 60% tard and cant seem to find the code that gets me 20% off Little help my hairy hungarian Quote Link to comment Share on other sites More sharing options...
