Mark350zShaw Posted January 10, 2016 Share Posted January 10, 2016 Hi just wondering if anyone else is having problems with there clutch. The bite point changes while driving sometimes possible air or something with the hydrolics. Clutch doesn't slip though. If anyone has had this problem can you let me know what you did to solve it. Thank you Mark Quote Link to comment Share on other sites More sharing options...
kernow zed Posted January 10, 2016 Share Posted January 10, 2016 Not that problem but when the car is driven for a while the clutch pedal seems slightly notchy when being released and sounds creaky. Been told it could be a slave cylinder problem but been like it for weeks now and like you the clutch doesnt slip. Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted January 11, 2016 Share Posted January 11, 2016 If the bite is getting lower and lower after driving for a while, it'll be the slave cylinder for sure. Happened to me. I changed it and it's never happened since. HTH Quote Link to comment Share on other sites More sharing options...
Ekona Posted January 11, 2016 Share Posted January 11, 2016 It's the slave or master cylinder. Change them both, parts are peanuts, it's the labour time for bleeding the fluid that's the killer. Quote Link to comment Share on other sites More sharing options...
Mark350zShaw Posted January 13, 2016 Author Share Posted January 13, 2016 Thank you for responses. Have you fitted your slave cylinder? was it OK to do? I have same problem on my van but the slave is in gearbox so don't fancy doing it so I just bleed the system now and then makes it fine again. Thanks Quote Link to comment Share on other sites More sharing options...
