Richie_k83 Posted January 8, 2016 Share Posted January 8, 2016 So it's a hard choice but I am putting her up for sale in hopes of getting into my first 350z! Located in West Midlands I would appreciate if people can refrain from telling me how much they think it's worth or asking me to break it. I'm not in a rush to sell. 1993 J-Spec NA Auto 138,014 miles (mix of miles & km I believe) Mot'd till 22nd May 2016 Scorpion Alarm & Immobiliser The car has undergone a fair chunk of work since I brought her. She's my daily so expect the miles to go up! Overall body condition, well, it's got the usual dinks, dents, scratches and stone chips of a car it's age and drivers wing is starting to fade slightly. The engine is solid, recently had the flex plate replaced as it had broken and was causing a noise. Whilst the engine was out, all seals and gaskets were changed apart from the head gasket. Along with the upper and lower sump being re sealed. Auto box shaft seals were replaced also. I have plenty of receipts and MOT certificates from previous owners. Engine has been fully serviced a few months back with HKS Oil, HKS Oil Filter, HKS Spark Plugs, HKS Air Filter, Cam-belt Kit, Auxiliary Belt, Auxiliary Idler Pulley/bearing, Engine Coolant, Distributor Cap, Rotor Arm, Fuel Filter, Fresh Auto Box Oil & new battery. Compressions Checked and Timing Set up. Engine; Standard apart from green vacuum hoses AirCon System Removed HKS Induction kit (still have oem air box with HKS panel filter) Exhaust; HKS Silent Hi-Power Stainless Cat back system Transmission; Standard Auto with modified Pajero side mounted oil cooler Brakes; Lexus 4 Pot front Calipers with new discs & Pads J-spec rear Calipers with new pads Hel hoses braided brake lines AP Racing fluid Suspension; Tein street flex coilovers Tein EDFC II Electronic Dampening Controller Whiteline 30mm heavy duty front adjustable sway-bar Whiteline heavy duty adjustable front drop links Whiteline 20mm heavy duty rear adjustable sway-bar Whiteline heavy duty adjustable rear drop links Body; Standard Body Cusco Safety 21, 5 point roll cage with safety 21 additional harness / strut bar Tinted front indicators Painted inside of headlamps black Wheel arches and floor waxoyled Rear wiper removed (still have it) Rear wing removed (holes covered with black film) Interior; Rear seats removed with side trims for cage (still have the trims) Fire proof Cage padding Arm rests trimmed with black suedette Tailored floor mats Roof lining and carpet dyed black Nardi Personal steering wheel Vibe speakers Sony MP3 head unit Standard Seats with seatbelt Wheels & Tyres; Brand New Japan Racing 18" JR10 wheels (Staggered fitment) New Toyo Proxes T1-R Front Tyres Dunlop Sport Rear Tyres Rays Durloc wheel nuts with matching lock nuts Rays valve caps Bad bits; Usual marks with age/mileage Centre console arm rest lid, hinge broken Dash and doors painted red by previous owner (up to you if that's good or bad) Electric aerial doesn't work Front splitter cracked and tied up with a cable tie stitch Gear stick loose, needs changing Pics; Price, £4500 ono Viewing welcome, Pm for more info. May do a straight swap for a stock 350z GT Coupe :) Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
